586,471 active members*
3,736 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Downside to Phase Perfect?
Results 1 to 3 of 3
    Dec 2007
    126
    Seriously considering one of their 30hp units. Running a 20hp CNC lathe, and 2 5hp CNC mills (typically one at a time). Currently running the mills on a 10hp rotary from american rotary. Not having issues, but need a convertor for the lathe, and thinking go bigger than I need, but "cleaner" power to prevent any damage to the mills as well.
    Really only downside Im coming up with is price. Which is quickly negated if I never have an issue with the machines! ANyone got any reaosn that this logic is silly, and I should just go with the right size rotary for the lathe?
    Dec 2003
    24223
    Re: Downside to Phase Perfect?
    Is there any reason you cannot run the mills with a 1ph in VFD on the spindles and the controller and the rest is probably currently all 1ph anyway.
    Al.
    Albert E.
    Dec 2007
    126
    Not sure I follow:
    Change the spindle motors out to VFD? or just run the 3 phase motor on single phase, like a static converter?
    If either of those, thinking cost, and headache, and doesnt get the lathe running
  1. Phase Perfect
    By Voss_Machine in forum Phase Converters
    Last Post: 07-28-2012, 12:55 AM
  2. Phase Perfect
    By Lee Olson in forum Phase Converters
    Last Post: 11-04-2009, 11:31 PM
  3. wtb: 20 or 30 hp phase perfect phase converter
    By gaugemate in forum Want To Buy...Need help!
    Last Post: 10-23-2008, 06:06 PM
  4. Lifespan of Phase Perfect
    By Shepard in forum Phase Converters
    Last Post: 02-18-2008, 02:25 AM
  5. Phase Perfect Question
    By bvweld in forum Phase Converters
    Last Post: 10-24-2007, 10:58 PM
