Originally Posted by
Mike_Walls
Complete newbie, here....I just got everything up and running for the first time the other day (Mach3, ESS, G540, MeshCam), but I have a problem that I cannot seem to fix.
I ran the skull and crossbones G-code freebie that comes with Mach, and the parts of machining where the bit should lift up out of the stock and move to the next area before making the plunge never seems to happen. My bit just plows right to the next piece- carving a track along the way. At first I thought it might be an issue with that file, so I bought a cheap puzzle from CNC Make, loaded it in Meshcam, played with it a bit and generated a tool path. Everything looked good until I started the cycle. The same thing happened. Why is the bit not lifting up out of the material before traveling to the next piece? I watched the tutorial video on homing/limits, but I don't see what I might have missed...yet I know it has to do something with the way I set up my Z..... I'm stuck.
