586,112 active members*
3,089 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Converted CNC Bench top Lathe Motor Wiring Issue - Brazil 220V to US 220V
Results 1 to 9 of 9
    Dec 2014
    17
    Hello everyone. I have a lathe from brazil that uses 220V at 60HZ and am trying to rewire it for use in the US market. Brazil uses 220V on a single line and not 110V x2 like in the US.
    The motor has no real markings to identify it other than a plate with the specs and a script like logo with letters that overlap that is hard to determine what it is (see image).
    Attachment 261258
    The motor has 6 poles: u1, u2, v1, v2, z1w1, z2w2. The current configuration indicated that the rotary switch powers U1 for forward and U2 for reverse. z2w2 is connected to neutral and z1w1 is connected to a positive. (see image)
    Attachment 261260
    One capacitor is connected to v1 and the other capacitor is connected to v2. The other leg of both are connected to z1w1
    There is continuity between u1 and u2; v1 and v2; z1w1 and z2w2
    Can anyone help identify this motor in so that I may get a diagram for it or possibly shed light on how to get it to run on US 220v or even 110v would be fine.
    Larger versions of the pictures are at Untitled Document
    Thanks in advance for any help anyone can offer.
    24221
    Re: Converted CNC Bench top Lathe Motor Wiring Issue - Brazil 220V to US 220V
    There is no difference in use between countries that use single phase centre tap supply and those that use a single phase and a neutral of a 3 ph supply such as is done in Europe and elsewhere.
    If you have the connections for Brazil, it will be the same for N.A. 240v.
    Connection Diagrams - U.S. MOTORS
    Al.
    Albert E.
    Dec 2014
    17
    Al,
    That sounds right to me - I did try and no go but it may be the switch. It has a KDEU JD3 switch (similar to the JD12 but must be OEM version for SIEG). It is a relay style safety switch but it didn't appear to "trigger" when hooked up. I will bypass that and see if I can power up as there may be something that needs changed in the switch wiring.
    The people at SIEG were super concerned that it wouldn't work in the US market and it may be because of the switch - who knows. I was sent the wrong one by accident and as opposed to going through shipping it back I decided to use it.
    Thanks for the reply and the link - that is SUPER useful. I will do some testing and report back if I get it running.
    Dec 2014
    17
    Thanks again Al!!!
    I got it running. I suspected US 220V would work but when it didn't I thought I was wrong. Your post motivated me to recheck everything and sure enough I found a safety switch catch that got slightly bent in shipping. Bent it straight, wired it up and it was good to go. Only thing that needed changed was the plug for the mill head attachment that needed the second pole brought to a neutral to bring it back to 110V.
    24221
    Glad to help.
    Al.
    Albert E.
    Apr 2003
    354
    Glad you got it going!
    Now, where's the pics of the rest of the lathe conversion. Far as I'm concerned, there are never too many CNC lathe pics.
    Dec 2014
    17
    D,
    Since you asked I will post a few pics here in a couple of days; let me get it all back together.
    I will say that I got to cheat a bit on the conversion as I work for a small manufacturer of CNC machines and we happen to be direct with SIEG (thats how I got a Brazil machine - as opposed to shipping it back out of the country I bought it from my company for cost). It is funny though because the lathe is blue and the mill head is red.
    Cheers.
    Apr 2003
    354
    Lucky you with the direct connection!
    So this is a 3-in-1 machine? Are all 5 axes CNC?
    Milton
    Dec 2014
    17
    Milton,
    It is a mill-lathe combo. I have control of the spindle, Z and X on the lathe and when in mill mode X, Y, Z and spindle on/off (in the Mach I use the lathes long axis as Z and the cross as X - in mill mode use the lathes long axis as X, the short as Y and the spindle height as Z). Hopefully I have it all put together this week since I have a couple extra days off for X-mas and I will post some pics.
    My next project will be my U1 - it is a vertical / horizontal knee style mill. Very cool machine.
    Cheers,
    Gio
  1. Bridgeport R2E3 delima, 220v VFD 3 phase Versus 220V Single Phase
    By ronderkis in forum Bridgeport / Hardinge Mills
    Last Post: 03-25-2015, 04:01 AM
  2. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
  3. Smithy Granite 220V brushless motor upgrade wiring
    By MasterOfKrikit in forum Smithy
    Last Post: 02-06-2012, 07:05 PM
  4. VFD Wiring from 220v Converter
    By TheProCreator in forum CNC Machine Related Electronics
    Last Post: 09-01-2010, 10:42 PM
  5. Wiring a 220v DOERR/Emerson Compressor Motor
    By Thazul in forum CNC Machine Related Electronics
    Last Post: 01-14-2010, 09:29 PM
