the troubles continue. My KB Electronics KBAC 27D 2HP VFD controller
causes really bad vibrations in 2 different motors: 2 HP 3600 RPM
Emerson and 1.5 HP 1750 RPM Dayton. Both are Invertor duty, brand new motors from Grainger. So is the controller. 220V in , 3 phase 208 out.
While it is not that bad with 2HP , as it is used in belt grinder, the
other motor was supposed to become VFD drive for my 9x20 lathe. With it shaking like this (NOTHING on the shaft, firmly bolted down to a massive bench, it shakes it badly, throughout whole range of speeds) there's no way it is going to work on a lathe. Vibrations only disappears at the max RPM.
To load it some, I removed a chuck from a lathe and chucked it right
onto the shaft of 1.5 HP. No effect.
What gives ? Is it typical for VFD contoller to induce this type of
vibrations ? I reckon not, as so many people use VFD drives on their mills and lathes ... I am @ loss.
Will call KB electronics, now that I know it is not a problem with a
motor.
If I spin both motors to high RPM, and then turn off the controller,
the vibrations instantly disappers and motors become smooth as silk and coast down to stop.
