586,516 active members*
3,363 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > KM5P graphics screen not working.
Results 1 to 9 of 9
    Sep 2004
    48
    Graphics screen quit on a KM5P max 32.
    I understand the components of the text and graphic screens are different.
    What is the best way to figure out what is wrong, with out causing damage?
    Thanks in advance,
    Mike
    Feb 2006
    175
    Re: KM5P graphics screen not working.
    Have you moved the mill recently ?
    I would check all plugs to see if they are tight.
    Then I would see if the filament in the CRT tube is illuminated. If not you have voltage failure of a bad CRT.
    If it is lit , then a component failed
    Can't help with trouble-shooting but if the monitor and circuit board are at fault
    you can look at this guy
    http://www.cnczone.com/forums/hurco/...r-repairs.html
    Good Luck
    Rich
    You may want to read the posts that are listed right under your original post , where similar issues have arisen in the past
    Sep 2004
    48
    Thanks for the reply.
    No recent moves
    Did the uplug, clean, and plug connectors and boards.
    I may have plugged the 10 pin, J55 connection on the driver backwards. The small fuse on the board blew,as well as some magic smoke leaking out.
    Replaced the fuse, corrected the 10 pin connection.
    I took the driver pcb out and inspected it for obvious damage.
    Just wondering how to identify the bad parts....
    Mar 2013
    156
    Does the end of the tube glow?
    Steve
    Sep 2004
    48
    I will not be at the machine til later. I will check it then.
    Sep 2004
    48
    No glow at the end of the tube.
    Mar 2013
    156
    When mine did not glow I had to get a monitor. But not sure since the smoke got out
    Sep 2004
    48
    Rich,
    Thanks for the tip.
    Sent him an email.
    Hope to hear something soon.
    Sep 2004
    48
    Put in a new resistor. End of tube now glows when powered up. Still no picture on graphics CRT
    Has the CRT gone bad?
  1. Ultimax replacement graphics screen
    By tallenttoolroom in forum HURCO
    Last Post: 04-17-2023, 12:06 PM
  2. Replies: 1
    Last Post: 05-08-2015, 03:40 AM
  3. Replies: 12
    Last Post: 01-29-2013, 02:33 AM
  4. Why is the graphics screen doing this? KM3P Ultimax II
    By pondringjunkman in forum HURCO
    Last Post: 12-23-2012, 01:01 PM
  5. 2412 graphics screen
    By Larry Myers in forum Sharp CNC
    Last Post: 03-12-2008, 01:36 AM
