586,236 active members*
3,497 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > How to access the Geneva drive?
Results 1 to 7 of 7
    180
    The Geneva wheel has a jerking motion which seems like the drive might have a loose grub screw. How do you gain access to the Geneva drive to tighten things up? It's above the wheel but located in the back of the umbrella where you can't access it.
    180
    Re: How to access the Geneva drive?
    It wasn't as hard as I thought. Pull the top covers and there are four bolts holding a plate that the motor is attached to. Turns out the drive was solidly attached to the motor shaft. The Geneva wheel still has a jerky movement in CW direction. Sensor maybe?
    Feb 2008
    547
    I have seen the roller bearings dry out or rust up on the umbrella shaft and cause that. Try using an oil can to drop way oil into the roller bearings and on the shaft. If it improves then that mostly likely is your problem area to fix. If not, look elsewhere. We replaced all the electrical connectors on ours once to solve a 'sensor waiting' problem and a index until it timed out problem...FADAL wire connectors are notorious for that.
    180
    Thanks scadvice. I'll pull the cover and take a look.
    180
    Still trying to figure this out. The motion is jerky from about tool 20 to about tool 3 and then smooths out for the rest of the tools. The Geneva drive looks to be over-rotating by a quarter turn or so when the motion is jerky and more or less only rotates 360 degrees during the smooth sections.
    We tried applying some thick grease to the geneva dwell cups. This has made the problem go away at least for now.
    Jun 2008
    51
    Also check to ensure that the two bolts holding the tray plate to the main arm are secure. On the 4020 here, the spindle would fault out above the tool holder during a tool change. Turned out the two large bolts were backed out allowing the tray to tilt, causing the sensor to trip.
    180
    Thanks Jon. I'll look at that.
  1. Toolchangers and Geneva Mechanisms
    By SCzEngrgGroup in forum Uncategorised MetalWorking Machines
    Last Post: 07-08-2012, 09:12 AM
  2. v22 access denied
    By dertsap in forum BobCad-Cam
    Last Post: 01-20-2010, 07:28 AM
  3. FADAL 3016 Turret motor problem (geneva)
    By kentsui in forum Fadal
    Last Post: 10-02-2007, 08:14 PM
