586,076 active members*
4,023 visitors online*
    Nov 2003
    17
    G54 zeros on reset
    Purchased a used Kitamura HX400ia with Fanuc 16i. How to stop from zeroing out the G54 when reset is pressed.
    Kirk
    Kirk
    2932
    Re: G54 zeros on reset
    Do you mean that it puts zeros in the X,Y and Z G54 offsets in the Geometry Offset page, or that it makes G54 the active WCS when you hit reset?
    If it's the latter, I think you want to change 1201 bit #7 to 0
    WZR Upon reset, the workpiece coordinate system is:
    0 : Not returned to that specified with G54
    1 : Returned to that specified with G54
    Nov 2003
    17
    Thanks dcoupar, The issue is that when reset is pressed, the G54 offsets are changesd to zeros.
    Kirk
  1. PCB GCODE zeros of top and bottom layer don't match!
    By matthew798 in forum PCB milling
    Last Post: 10-28-2014, 01:45 PM
  2. Zeros For Different Tools With No Home/End Switches
    By xxtoni in forum Mach Software (ArtSoft software)
    Last Post: 04-02-2013, 11:19 PM
  3. Machine positions zeros itself!
    By cdrd03 in forum Mach Mill
    Last Post: 05-22-2012, 10:12 AM
  4. Zeros reset
    By jcambra in forum Mach Mill
    Last Post: 04-03-2010, 04:31 AM
  5. Manual Setting of Work Zeros (0-M fanuc)
    By venomgrrrl in forum Fanuc
    Last Post: 07-08-2009, 06:43 AM
