586,121 active members*
3,032 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > 2006 Haas TL1 cross slide to spindle centerline
Results 1 to 6 of 6
    Sep 2011
    43
    I'm installing a Dorian rotary tool changer that I will need to make a spacer block for. I purchased the lathe new in 2006. I measured the centerline to cross slide top and came up with 4.320". The new specs show 5.5" so I assume Haas changed something along the way. Does anyone have the original specs on a 2006 TL1? I can't seem to find mine.
    John
    Sep 2011
    43
    Re: 2006 Haas TL1 cross slide to spindle centerline
    Any help?
    John
    Jul 2005
    12177
    You say the current spec is 5.5" so probably even if you found an older spec it would also be to only one decimal; which is not precise enough. For installing a toolpost you need accuracy of something like +/-0.001" so you need to do the measurement to this the level of precision and work with that..
    Sep 2011
    43
    Quote Originally Posted by Geof View Post
    I'm not looking for +/-.001, I'm wondering if the older TL1 were 4.5" instead of the 5.5" on the current ones. Sounds like they did something to the cross slide to gain another inch.
    John
    Dec 2011
    295
    2004 Haas tl1 spindle cl =4.819 as of 10/13/11. Do you need any more work envelope dimentions? TL1 v2 was changed 2014 sept for a bigger spindle bore and production enclosure only. Higher spindle speed also.
    Sep 2011
    43
    Quote Originally Posted by LeWhite View Post
    Thanks. That answers my question.
    John
  1. Spindle Center to Cross Slide Measurement.
    By hrdg4me in forum Haas Lathes
    Last Post: 04-13-2013, 12:56 AM
  2. cross slide crabing
    By fragger6662000 in forum Mini Lathe
    Last Post: 12-11-2011, 11:27 PM
  3. Metal for cross slide
    By arizonavideo in forum MetalWork Discussion
    Last Post: 11-25-2009, 11:37 PM
  4. cross slide
    By nantz in forum Benchtop Machines
    Last Post: 07-13-2006, 12:09 AM
  5. cross slide
    By nantz in forum DIY CNC Router Table Machines
