586,035 active members*
3,712 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Boring a Hole in 4140 steel
Results 1 to 14 of 14
    Apr 2005
    19
    Hello
    Help, help please
    Can somebody give me some advice in how to make a .187 to .1875 hole in a 4140 steel, I have tried almost everything reamers boring bars and I'm having problems holding size.
    Also if somebody has experience in turning 4140 material, I'm havin problems braking the chips all I get is a very stringy chip
    thank you
    Jun 2006
    629
    For your stringy chip problem, what kind of tool are you using?
    For reaming, try carbide tipped or solid carbide reamers.
    Is your reamer running true? How much material are you leaving in the hole?
    "It's only funny until some one get's hurt, and then it's just hilarious!!" Mike Patton - Faith No More Ricochet
    Apr 2005
    19
    Hey big mak
    for my chip problem I'm using a 55-deg diamond insert with a .015R
    for the hole problem I already try carbide reamers and my reamer it is running true. I tried boring it first and then ream but after running a few parts I get some parts undersize
    Jun 2006
    629
    What DOC are you using for the lathe tool? Feed?
    What speed and feed are you using for the reamer?
    Apr 2005
    19
    I 'm turning a .621 stock diam down to .375 finish size at about 300sfm
    for the reamer I tried anything from between 400-1500Rpm with a feed rate of 6 - 13 IPM
    Apr 2005
    19
    by the way The length of the part I'm turning is about 21 inches
    the bore hole is only .400 deep thru hole
    two different parts
    Jun 2006
    629
    As for turning, to break the chip, you must make sure that your depth of cut is larger that the tool nose radius. Your feed should be around 0.010"per rev.
    U using CNC for reaming? Try using G85 to Feed in feed out. How big is your hole before you are reaming it? I'd make sure its only around 0.182" or so.
    Jun 2006
    629
    You have a follower rest?
    Apr 2005
    19
    I'm using a CNC Swiss machine for both parts and I did tried feeding IN and Out and my hole size is .182 diam.
    Jun 2006
    629
    with a swiss type machine you should be able to get a good aggressive feed on the turning part.
    As for the Reamed hole, areyou getting enough coolant to the tool?
    This can be tricky because with a small reamer the chips can fill the flutes and keep the coolant from getting to the cutting edges.
    Maybe just maybe try for the fun of it ream with G83 to let the chips come out and get coolant to the tip of the tool.
    It's easy for us to come up with ideas when we're here. Always a different story when you're at the machine.
    Apr 2005
    19
    well believed or not I can only go up to .007 feed rate before I get an overload alarm, I think the machine just don't have enough horse power to rip the material.
    As for the hole I'm going to give it a shot to the G83 ... tomorrow
    Thanks big mak for your help and Ideas if you have any other ones please post it I will check them tomorrow .. I think is time to give it a shot to try to sleep with all these ideas
    May 2005
    1810
    You might be work hardening the material. Are you using coolant? Keep the material cool during machining.
    It sounds like you may have work hardened your piece.
    Scott
    Consistency is a good thing....unless you're consistently an idiot.
    Aug 2006
    246
    Try increasing the sfm for turning. I'm not sure what type of geometry or coating that you are using but 300 sounds slow to me(I've roughed 304 S.S at 600). I'd run at least 500. Are you going O.S. or under with the reamer?
    Apr 2005
    19
    Hi cdlenterprises
    My reamer was going overzise, Today I tried a Circle boring bar with a tin coating insert with a .015R and is working out great , after drilling the hole I bore it and then go back with a reamer to de-burr a cross hole
