586,104 active members*
3,331 visitors online*
    Sep 2011
    43
    TM1 3/4 hp coolant pump
    I am building a new sump and was curious which 3/4 hp coolant pump some of you guys used?
    John
    Dec 2010
    1230
    Re: TM1 3/4 hp coolant pump
    On my TM2P I have the factory HAAS high pressure pump. On my Tormach I use a 3/4 hp pp from Harbor Freight. The HAAS definitely had more pressure, but the HF one works well with three 1/4" lines and a garden hose for wash down both fed by 5/8 ID tubes
    Brian
    WOT Designs
    Sep 2011
    43
    Quote Originally Posted by WOTDesigns View Post
    Brian
    WOT Designs
    Brian,
    Is the Haas pump single phase?
    John
    Dec 2010
    1230
    No, it is 3phase. They convert the main power to the machine to 3phase if ordered with the HP pump which I preferred anyways.
    Brian
    WOT Designs
    Sep 2011
    43
    Brian
    WOT Designs
    Brian,
    Thanks. I have 208v three phase going to the machine so I could put a relay on it for three phase.
    John
  1. 325 Coolant Pump
    By TurtleRacing in forum Tree
    Last Post: 04-02-2012, 07:51 PM
  2. Coolant Pump
    By bobs_charger in forum Tormach Personal CNC Mill
    Last Post: 04-16-2009, 11:19 PM
  3. coolant pump
    By JACKSMACHINE in forum Fadal
    Last Post: 05-22-2008, 09:13 PM
  4. TM2 Coolant pump
    By Peter Gibbs in forum Haas Mills
    Last Post: 05-03-2008, 06:11 PM
  5. coolant pump ???
    By Loadedagain in forum Charter Oak Automation Support Forum
    Last Post: 01-03-2007, 07:54 AM
