Originally Posted by
rugbyal
I have an SF series machine that the ball nut on the Z axis has cracked. The bearings are fine but apparently the threads filled up with crud and finally bound up.
Two questions,
1) Where can I get one. I believe it is made of Turcite plastic. I have looked on the web and found similar looking ones.
2) In the future, what is the best way to lubricate these. The tech that came out when we installed the machine said to spray it occasionally with silicone spray. When I cleaned out the ACME threads, the gunk was almost solid and more or less chipped out.
