I am unable to figure out how to set parameters 600-604. I can update all the normal parameters 000-407, & PC Timer parameters 1001-1040.
I must be overlooking some setting, or procedure.
Can someone walk me through setting these?
Cheers,
Steve
Cheers,
Steve
These parameters use for options activation.Usually they actuate graphics control. Tell please me series/version of your software.
The control is on a Mazak H-25 horiz machining center. Software is 901 series, ver 5.
Steve
This old series/version software haven't access to parameters 600-604. To this parameters have access only systems Fs 6M-B II level up. These systems are completed with Main Board PCB A16B-1000-0030.
You can change them trough PC Parameters 3001 for 600, 3002 for 601 etc.
f-bu,
Thanks for the help. That enabled me to set the parameters, and solved that issue.
Cheers,
Steve
