586,089 active members*
3,870 visitors online*
Results 1 to 7 of 7
    Dec 2010
    1230
    RFQ Lathe Turned (Swiss?) Production Parts
    Hello all. We have been machining these in house hand loading into a VMC and mill turning, which is fast enough but it takes us 5 operations that way and should only take be significantly faster on an appropriate lathe considering how little work there is.
    Bar is .297 O1 Annealed Tool Steel. No OD turning. Just face, chamfer, chamfer back, cut off. Burrs are A-OK all around as they will be tumbled in house upon arrival, EXCEPT no pip on the indicated face as it is referenced on the next operation.
    Please quote 500pc qty for the first few runs (every few weeks), and 2,000 pc (per month/2months?) after the first few runs.
    Material supplied in 36 or 48 inch lengths. Currently I buy 36" but have quotes out for 48" also.
    Attached Thumbnails Attached Thumbnails STOCK BLANK - LATHE TURN A02.PDF
    Re: RFQ Lathe Turned (Swiss?) Production Parts
    I tried PM'ing a quote but it says your inbox is full.
    -Dylan
    Dec 2010
    1230
    [email protected]
    Brian
    WOT Designs
    Feb 2014
    92
    Hi WOT Designs
    Is this possible to send the 2D drawing to us at this email address [email protected] as we cannot download. Thanks.
    BR
    /SL Wong
    Sales Manager
    Proto Tree LLC
    website: Proto Tree
    email: [email protected]
    Apr 2010
    64
    Hi, I forgot to mention in my quote that I was planning to precision surface grinding the parts on a cnc cylindrical grinder. Also your pm box is full. Cheers.
    Joe
    Dec 2010
    1230
    Definitely don't need anything near that level of precision or and on turning for that matter. Just need raw bar cut to length, one end faced, both ends chamfered.
    I think I have my vendor for these already. Still testing the machining processes, hardening then coating on the samples.
    Brian
    WOT Designs
    Aug 2013
    53
    I know you might have a vendor for these, if it falls through I have a swiss machine and could crank these lil guys out for you. shoot me a pm if your new supplier falls through!
  1. First Turned Parts on SlantPro
    By menzzer37 in forum Tormach Slant Lathe
    Last Post: 07-11-2015, 04:35 PM
  2. Replies: 2
    Last Post: 07-10-2015, 02:18 PM
  3. RFQ two turned alum parts
    By rdoty in forum RFQ (Request for Quote)
    Last Post: 02-07-2013, 10:08 PM
  4. Replies: 15
    Last Post: 04-14-2011, 05:33 PM
  5. RFQ - turned parts
    By Runner4404spd in forum Employment Opportunity
    Last Post: 11-01-2006, 04:57 AM
