586,290 active members*
3,934 visitors online*
    Dec 2014
    Milling a 16 finish on a 60 DEG internal chamfer
    Hello all!
    I am working to put a 16 finish on an internal chamfer.
    It is a chamfer inside another hole where the diameter goes from .516 to .208 and the chamfer is on the .208 diameter.
    Currently I have tried a normal circular chamfer toolpath which left chatter. I then tried (using a 3/8 4-flute chamfer mill carbide/uncoated) to do a peck drill path to rough out the chamfer (it's somewhere between a .050 and .100 chamfer) then a G82 drill cycle with a 3 second dwell and was getting chatter. I have tried really slow feeds and speeds (.4 IPM with 300 RPM), a moderate feed and speed (1.5 IPM and 2400 RPM) and a slow feed and fast speed (.4 IPM and 7000 RPM). I have tried various depths of cut from .001 to .010 for the finish. Nothing has worked.
    I am cutting 3-16 Stainless on a Doosan Daewoo 3016 Vertical Mill.
    My next thought was to try some improvisational Burnishing.
    Seeing as burnishing tools are very expensive and I haven't seen any with a 60 DEG taper I need some creative solutions.
    I am planning on trying to use a 60 DEG chamfer tool and spinning it backwards (M2) at a very slow feed and speed (.2 IPM 100RPM .001 DOC) to try and burnish the chamfer.
    Has anyone else tried this? Am I crazy? Any other ideas on getting a 16 finish?
    Thank you!
    Luke
    CNC Mill Programmer/Operator
    Dec 2014
    Re: Milling a 16 finish on a 60 DEG internal chamfer
    Here is a hastily painted picture of the chamfer
Name:	chamfer picture.jpg
    Dec 2014
    In case anyone stumbles upon this and needs a solution here's what we did:
    We rounded the cutting edges on a 60 deg chamfer mill and then using an M4 we spun it counterclockwise at a spindle speed of 200 RPM and udes it to burnish the last .002 of the chamfer. It worked out pretty great!
  1. milling a chamfer with endmill
    By Quick3 in forum G-Code Programing
    Last Post: 11-30-2022, 02:57 PM
  2. milling a big chamfer with siemens control
    By russellthackray in forum SIEMENS -> GENERAL
    Last Post: 05-15-2015, 04:14 PM
  3. How to chamfer/finish pass
    By wildwhl in forum CamBam
    Last Post: 10-09-2012, 01:49 PM
  4. milling a chamfer
    By russellthackray in forum FeatureCAM CAD/CAM
    Last Post: 06-02-2012, 05:23 PM
  5. Chamfer milling speed data?
    By JMFabrications in forum Uncategorised MetalWorking Machines
    Last Post: 09-13-2007, 06:30 PM
