Hi all.
My problem is with end mills while surface milling.
As you will see from the attached pictures, after milling, there is RIDGES between the borders of each passes.
Ok, i do not expect a perfect shiny surface, but at least it could be flat.
When i place an knife edge square, i can see that surface is not flat.
What could be my mistake ?
Any suggestions are appreciated.
Thnx.
