586,096 active members*
3,112 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > How to Shutoff the Display on Fanuc 16i control
    Aug 2009
    4
    I don't know if it is possible or if I try to do something impossible,
    For the Holiday, I want to keep my machine open but put the screen (display) off.
    Any body know how to?
    Feb 2008
    586
    Re: How to Shutoff the Display on Fanuc 16i control
    Two buttons at once. Either shift-cancel or graphics cancel
    You must press cancel and one of the function buttons. (Pos, system, offset, or message) This work only if parameter 3123 is set to 0.The parameter has a setting of minutes, so if it were set to 30, after 30 minutes with no activity on the MDI keypad the LCD display will shut off. If the parameter is set to 0,
    pressing the CAN key and any Function key will also activate the screen saver function.
  1. Replies: 0
    Last Post: 09-06-2014, 04:58 PM
  2. Display shutoff while program running
    By djc1965 in forum Haas Mills
    Last Post: 02-27-2012, 09:58 PM
  3. Display and control
    By outsider787 in forum CNC Machine Related Electronics
    Last Post: 09-06-2011, 08:34 PM
  4. Mach 3 shutoff
    By oldskimmer in forum Machines running Mach Software
    Last Post: 08-10-2009, 04:17 AM
  5. why auto shutoff?
    By spock in forum Sharp CNC
    Last Post: 01-27-2008, 04:43 PM
