I picked one of these up last month from a US distributor on Ebay when the seller dropped the price to $400 shipped. I read a ton of reviews before buying it, so I was aware that it was not the best thing out there. But at $400, I could barely buy a tube and supply for that. So, I bit the bullet and bought it with the intention of modding it right off the bat.
I am too lazy (busy?) to do up a proper blog, and it seems quite a few people here have this cutter, so if nobody minds, I will detail my upgrades here.
First off, I gutted the entire thing. The only thing I left still attached was the high voltage wire between the tube and the supply since I didn't want to risk breaking this tiny wire trying to remove the tube and silicone and desoldering. When I say gutted, I literally mean every piece of hardware except those two items was removed right down to the crappy stripped screws (they used countersunk screws on non-countersunk holes!) I then set about with a plan.
Also while I have the parts out, I am generating CAD models of all of the mechanical parts in order to 3D print replacement parts if ever needed and also for the purposes of modding any of those parts if I want.
I have broken the system down as such:
1. Electrical
2. Safety
3. Air system
4. Cooling system
5. Exhaust system
6. Mechanical
7. Electronics
8. Aesthetics
9. Laser/optics/alignment
These won't be covered in any particular order except the order in which I perform the mods. And some of the systems are intertwined, so there may be some repeating of information.
Laser/Optics/Alignment:
I started with the laser bay area since I didn't want the tube dangling loose for very long. I removed the tube and cleaned it, then wrapped it in a towel and taped it up and set it on top of the cabinet while I worked.
Inside the laser bay area, I removed the crappy collapsed water tubing they sent with it. I installed latex tubing instead and carefully zip-tied it to the laser tube. Some soapy water helps slip the tubing on very easily.
I had read a bit and decided it made sense to input the water at the front of the laser and out of the back which is the opposite of how it was labeled originally. I installed check valves on the latex lines near the laser tube nipples. The purpose is to keep water filled in the tube with some pressure to prevent air bubbles from forming due to a cavitating pump or unlevel surface. It will also help a bit when working on the cooling system to prevent water from running all over.
It may mean using a more powerful pump if there is some restriction in the flow due to these check valves, but the benefit of having them outweighs that IMO.
Attachment 262876
I then used foam cable-clips to secure the water hoses and to add some strain relief to prevent pinching in the lines. I picked these up in the home theater section of Home Depot.
I added rubber grommets to all the holes in which wires would be routed to prevent wire chaffing from rubbing on the metal edges. I placed a piece of high-density foam in the back wall of the laser bay to protect the laser if moving it around jars the tube around a bit. Also because I slid the laser all the way back to get some more room in the front for eventually adding a red alignment laser (still not enough room!) I didn't want the glass tube sitting up against the metal where it could get banged accidentally.
Attachment 262878
I removed the hard rubber spacers that were put under the laser in the holder brackets and replaced them with neoprene strips cut from a mouse pad. I placed these on the top and bottom. This also provides a bit of a spring to adjust the laser up and down without putting too much pressure on the glass tube.
I also removed the over-sized bolts holding the brackets in place and replaced them with M5 bolts with a flat washer and locking washer. This actually allows you to slide the brackets side to side about 5mm to help center the laser since there are actually slots in the chassis for this purpose. With the over-sized bolts, you couldn't move those brackets.
Then I added a magnetic reed switch to the edge where the lid rests in order to create an interlock. The magnet is mounted on the lid. The switch opens when the lid is open and closes when the lid is closed. Response is very quick. These are meant for an alarm system to sense when doors or windows are opened. They can be picked up from Radioshack.
Attachment 262880
I also noticed a hole in one end of the lid about 4mm in diameter. It was likely meant for some type of solenoid operated pin lock which would lock the lid when the laser is operating. I may add this feature at some point.
Finally, I installed a 1K ohm NTC thermistor to the output end of the tube using electrical tape. Not the fanciest thing and it is being reworked. The purpose of this is to connect this to a simple little circuit that will open a relay if the temperature is equal to or greater than some set point. If the laser is getting too hot, it will be disabled as part of the interlock system.
Attachment 262882
This wrapped up the laser bay section of the mods (for now) except that I ordered new molybdenum mirrors and mirror holders from lightobjects. I have not received them yet, though. The mirrors that came with the unit were the gold surface mirrors. They weren't in terrible condition, but they seemed a little cloudy to me and I wasn't satisfied after cleaning them. I read a lot about the mirrors and lens being crappy in these. So the originals will be stored away as emergency spares.
There is a little bit more going into this section, but will be covered in another sub-system later.
Electrical
I will be running a RAMPS 1.4 based controller. I also planned to add several 12V accessories. So, I ordered up a 500W ATX PC power supply to give me ample 12,5,3.3, etc supplies. This will be modded a bit for this purpose. I haven't finished it yet, so I will be detailing that later.
I decided that I wanted two electric outlets on the back of the machine for the exhaust, air compressors, or whatever. I also wanted them switchable and possibly under control of the RAMPS controller. So I threw together a little junction box with two 10A optically isolated relays and split a duplex outlet on the hot side. I then knocked out a rectangular hole in the back of the chassis using a hand nibbler (I would use a body saw for a hole this big next time!) The end result is two fully grounded outlets switchable with logic level signals.
Attachment 262884Attachment 262886Attachment 262888Attachment 262890
The laser supply is the typical MYJ40 deal which (fortunately) allows PWM power modulation. This will be controlled by the RAMPS controller. I cracked open the supply to check it for bad solder joints as I read several mentions of bad supplies. I noticed there was a header for a 24V fan, but no fan. So, I ordered an 80MM 24V fan and installed it in the top of the power supply using vibration isolation spacers. I don't know how hot the supply normally gets, but it was there, so I may as well add it.
While I had the supply open, I was also looking for a point to tap into the LED that turns on when the laser is on. I found it was just connected directly to the K+ terminal. So, there I have a point for "laser on" indication which you will see in use later. This K+ line is also connected to the switch on the original control panel labeled "TEST" which fires the laser manually. I will be routing this out to a phone jack on the side of the chassis in which a remote switch can be plugged in to assist in aligning the laser.
That's it for the laser supply. I added the fan and buttoned it up as the solder joints looked good. The connectors are well labelled, so I knew where everything needed to connect. I won't be using the 24V portion of this supply, so it will only be operating the laser.
The steppers are being replaced with 12V steppers with a higher holding torque and a 0.9 degree step angle. The RAMPS controller has DRV8825 stepper drivers which are capable of 1/32 microstepping. So, the capable resolution of the steppers will likely exceed the resolution of the laser itself. It should also be much quieter and faster in operation.
Finally, I did grind away the paint from the earth ground terminal, but I am really not sure why this is necessary if you are using a grounded outlet. Anyone care to clue me in? It was just connected to the ground pin on the IEC plug anyway. If I don't need it. I will just do away with it. I am assuming this is a CE/IEC requirement that if something were to short to the chassis, I wouldn't be electrocuted touching the chassis. This could be solved by just attaching the ground to a screw somewhere on the chassis. Why the need to run a wire from that tie point to the ground in the same outlet you have it plugged into (as per the video included)?
Aesthetics
I gutted the control panel and ordered up some nice black acrylic to make a new panel. With the RAMPS controller, I also got the 12864 full graphics smart display with an SD card socket. The SD card is under the display which will be flush with the control panel. You wouldn't be able to get to it without lifting the lid. So, I ordered up an SD card extender to move this to a more convenient spot.
I also ordered a lock-out emergency switch which will cut ALL power to the machine. And also a red illuminated arcade switch which will act as a kill switch for the RAMPS, which just kills the current job. The illumination in the switch will represent when the laser is in operation.
I also have a touchscreen embedded linux system that I may be installing which will add a network server to the cutter as well as some control from pronterface or similar. It won't fit into the control panel with everything else, but it fits nicely above it, so I would need to knock out some more metal in the lid to install it. One idea for this is to have a library of g-code stored on it that can be called up on-demand.
I am installing an USB panel mount extension cord so I can also place the USB port in a convenient spot and don't need to install the RAMPS up against the side of the chassis.
For the build window, I don't know what the seller had inside the laser tube with the water, but when I pulled the tubing out, some of it leaked onto my build window and it etched itself into the plexi! I imagine it must have been antifreeze of some sort. So this will be replaced with some lexan. Nothing too special about that. But I might get all fancy and etch something into it.
Inside the build area, there will be LED strip lights at the front and back to illuminate the workspace along with a switch to turn these off/on.
This is as far as I will take this first post. As you can see above, I have plenty of more work to do so I will take pictures and detail the rest in future posts unless the mods freak out and don't want this posted here.
