586,075 active members*
3,993 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Hypertherm Plasma > Manual Gas Console OL Error..Shield cut flow
    Jan 2015
    I am using HPR260XD Manual gas console on Ficep machine, today when i switch on the machine the shield cutflow presuure is shown OL in the display. no other errors on the display, the pressur in the regulator is also normal.
    Jan 2013
    58
    Re: Manual Gas Console OL Error..Shield cut flow
    We have a HPR130XD with Manual gas console and we get the same thing happen when we change from cutting stainless steel to mild steel or vice versa if we have turned off the previously used gas cylinder.
    It seems for some reason that the console looks for both the last gas used as well as the gas you have selected for the current material, once we start cutting with the "new" gas we can turn off the one we do not need.
    It does seem strange that it should do this, maybe Jim Colt can explain why?
  1. Manual G-Code error in Mach 3
    By deuce217 in forum Mach Mill
    Last Post: 09-03-2014, 06:09 AM
  2. Hypertherm HPR260 manual gas console smells like ozone.
    By millwright79 in forum Haas Mills
    Last Post: 11-07-2013, 07:36 PM
  3. HPR 260 manual gas console smells like ozone.
    By millwright79 in forum Hypertherm Plasma
    Last Post: 11-07-2013, 01:50 PM
  4. glas flow tube for HD3070 gas console spareparts
    By mattiandrao in forum Hypertherm Plasma
    Last Post: 12-16-2010, 03:05 PM
  5. Looking for a used Hypertherm Manual Gas Console
    By RepL in forum Waterjet General Topics
    Last Post: 06-26-2009, 06:52 PM
