586,551 active members*
3,325 visitors online*
IndustryArena Forum > CAM Software > MadCAM > How to edit MadCam post-processor
Results 1 to 9 of 9
    My post processor "Mach3-Metric-5-Axis" refuses to create A0.000 and B0.000 commands in the text file. As a result, my rotary axes are kept at a previous angle. If I cut a back of a medal ( A at 180 degrees) first, then the machine would cut the front without flipping the part to A=0.
    Therefore, I always have edit my G-code manually.
    How can I edit my post-processor to make it always bring the A and B axes to ZERO between tool-paths?
    Michael.
    Mar 2004
    1661
    Re: How to edit MadCam post-processor
    Open up the folder C:\ProgramData\5XCNC\madCAM\5.0\Post Processors, make a copy of your post processor and go on and edit as you like.
    Keep a copy somewhere else if you make an upgrade or something.
    You also have a section in the help called Post Processing, check it out.
    Apr 2003
    1357
    If I understand correctly, I think you need to edit these sections:
    *TOOLPATH_CHANGE*
    *TOOL_STOP*
    If you don't have the *TOOLPATH_CHANGE* section, add it. Not all posts that ship with madCAM have all of the sections included. As Sven suggested, look in the help file for an idea of what is possible.
    Dan
    Nov 2013
    36
    I am having specifically this problem. All 4th axis commands work great as long as they are not A0. My post did not have either section mentioned, but I do no know what what the content of the sections should look like, or where in the txt file they are output. I have read the entire section of the help which is supposed to cover this, but without examples of the syntax I am having difficulty.
    What would the *TOOLPATH_CHANGE* and/or *TOOL_STOP* contain?
    Many thanks!
    O
    Apr 2003
    1357
    So just to be clear, your A value is outputing correctly except if it should be A0? What happens if it is A0?
    Nov 2013
    36
    Hi Dan,
    Thanks for getting back to me. All output is great except when A0, then is simply outputs nothing in the "a" space.
    I have been experimenting with the *TOOLPATH_CHANGE* area of the post and tried to add an "a" there, as that is where it had the most potential to do damage, but it now puts a huge number (albeit the same number, it is in the hundreds of millions and not divisible evenly by 360) in the place of "a". Any suggestions?
    Many thanks,
    O
    Apr 2003
    1357
    I'll have to look into this. Can you post your post-processor here for me to look at? I have a post for a 4-axis machine we use down in the USA, so I'd like to compare yours to mine and see if I see a difference that could be causing this.
    Dan
    Nov 2013
    36
    Absolutely. Thanks a ton for having a look at this. It is a barley modified Mach3 post. Thanks again,
    Apr 2003
    1357
    Try adding this to your post:
    *FIRST_MOVE*
    G16"a"
    G00"x""y"
    G00"z"
    *END_SECTION*
    G16 is the code for rotating the 4th axis on our machine. Yours might be different. This should get the rotation into your code, even if it is A0.
  1. Madcam/KMotion CNC Post Processor?
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-27-2013, 12:36 PM
  2. how to edit edgecam post processor
    By ineedhelp in forum EdgeCam
    Last Post: 06-26-2008, 07:41 PM
  3. post processor edit for hurco ncpp option
    By dannystooblue in forum HURCO
    Last Post: 04-09-2008, 03:50 AM
