586,060 active members*
4,165 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > What foam for aluminum casting?
Results 1 to 11 of 11
    63
    In the past, we had parts aluminum sand cast using patterns hand shaped from mdf and bondo.
    I now want to move to cnc'ing the patterns out of some type of foam. What foam should I use? Name brands? Types? I am totally new to foams.
    I would like the foam to be as "light" as possible so that I can run the cnc faster than with "heavy" foam. However, I presume that the foam needs to be heavy/stiff enough so that when the foundry is pressing the pattern into the sand that the foam does not compress or break.
    If you know of good foam suppliers for this kind of stuff in the Southern California are, please feel free to recommend them.
    Thanks!
    Jul 2006
    1062
    Try a google of "lost foam casting" you'll then see the way to approach this method. The main difference being no binder in the sand and that the sand is usually dry. Most of the lost foam casting i've seen has been gated only at the top...you may want to look at traditional gating and risers as i'd think it would give a better finish and a closer grain in the casting. Never bothered with it myself but once you see it you'll know how it's done. Any pottery suppliers near you? they have nice slips you could use hth
    Keith
    63
    Thanks for your suggestions.
    I am interested in using a regular sand casting process, not lost foam casting. I am only doing one-off projects.
    I would like a foam that I can CNC and then give to the sand caster. Ideally, the foam would not be damaged by them pressing it into the sand.
    Aug 2004
    2849
    Check buildyouridea.com he uses foam for aluminum casting forms.
    Nov 2004
    321
    I have one question:
    lost foam casting process, for example using 10mm foam sheet when cast aluminium how much is dimensions after 10mm aluminium sheet more or less.
    Aug 2004
    2849
    I believe the shrinkage is about 10% for a cast aluminum part....break out the mechanics bible....
    Mar 2006
    69
    Quote Originally Posted by ViperTX View Post
    He does - but it's all 'lost' in the process. I believe the poster is looking for a foam that will be able to be re-utilized.
    My question now is, if your only doing a one-off then why do you care if the foam goes away?
    Apr 2005
    1778
    Patternmakers use 1/4" per foot shrink rules for aluminum (about 2%).
    Feb 2006
    6
    it more like 1-2% for aluminum
    for 10% you must be thinking of jello
    Nov 2005
    105
    Best foam i've used are regular insulation foam.
    They are thick and soft, when casted, take the perfect shape with 1-2% shrinkage.
    Try to use a coating outside the foam. Home made formulas is dry wall paste mixed with masontry cement. Your casts will be as smooth as the foam you prepared.
    Live life like you never see another day
    Dec 2005
    9
    Quote Originally Posted by venomx999 View Post
    I too have seen several websites where the person casting just takes the foam part with risers and all, dips them in thinned out drywall compound (thinned out enough to flow into all the nooks and crannys) several times to get a good thick coating. Lets it dry and then pours dry sand around the whole thing to support it during the pour. This will be the route I go when I finally get my furnace fired and am ready to start pouring parts. ...just my .02
    Chad
    Tucson, AZ
