586,082 active members*
3,602 visitors online*
Results 1 to 17 of 17
    Feb 2014
    197
    4th Axis for G0704
    Who has done this and what tips can you share.
    I'm leaning towards using a 5C spin indexer and attaching a stepper or servo via harmonic drive (via eBay) if I can.
    Thank you!
    Nov 2009
    4415
    Re: 4th Axis for G0704
    Doesnt Simpson make one?
    A lazy man does it twice.
    Feb 2014
    197
    Yes and it is very nice. Out of my price range for the time being. Was looking at eBay for Harmonic drives. Some are not badly priced but need to understand more about what I will need. The other option is a 4" or 6" rotary table. That looks well enough documented that I can tackle it.
    Nov 2009
    4415
    I have a Sherline rotary table. It is actually a pretty nice unit for the price. Seems to be as accurate as I would need. The part size would be its biggest drawback.
    Feb 2014
    197
    Fastest, with that unit the conversion for stepper would be simple yet too many features would need to be added at additional cost. Looks like you would need an angle plate for vertical mounting and I would still want some sort of chuck as well. Tail stock will be needed either way I go. Thank you though.
    Mar 2010
    50
    I have the full sherline cnc rotary table setup if you want to take a gander at it. Tailstock, chucks, angle plate (fixed and adjustable). Also have the standalone controller I used before I got the G540 controller. It's small but really well built. My problem with it is software for cam. All I've done so far has been hand code.
    Feb 2014
    197
    This is the idea I would like to try but maybe with a 5C collet system.
    Attachment 263612
    CNC Router Rotational 4th Axis Dividing Head Gapless Harmonic Reducer Jaw Chuck | eBay
    - - - Updated - - -
    Quote Originally Posted by moto52000 View Post
    Glen 100%! Thank you.
    Nov 2009
    4415
    The Sherline unit mounts either way, no plates needed. Plenty of available accessories for their parts. To those not familiar with Sherline, the parts are very modular. Mine is not as Moto's is and uses the 4th axis of a G540 or HCNC pro boards.
    Feb 2014
    197
    Fastest have you used this as a 4th axis on your G0704?
    Nov 2009
    4415
    No but it wouldnt be a problem. I did use it on my A2Z.
    Feb 2014
    197
    The Adapter and 4 Jaw Chuck for 4" Rotary Table | eBay
    Something like this with a stepper motor might be the way I go.
    Nov 2009
    4415
    Here is mine.
    Attachment 264692Click image for larger version.
ID:	264694Click image for larger version.
    Nov 2008
    79
    Here is mine built on a harmonic drive transmission. I got less than $200 in it. 200 to 1 reduction. Not as stiff as commercial but only required a stepper adapter and a backplate.
    Attachment 265454
    Nov 2008
    79
    Sorry, double post
    Feb 2014
    197
    Quote Originally Posted by johncarpenter View Post
    Attachment 265454
    That is slick!
    Nov 2008
    79
    Potatohead,
    I have a website where I put up captioned pictures of the build of my 4th axis: Under construction but at least the pictures are there:
    4th Axis with Harmonic Drive – Under Construction | Carpenterswoodworking.com
    John C
    Feb 2013
    38
    https://www.sherlinedirect.com/index...TOKEN=55075363
    Sherline rotary tables on sale this month. I just received mine in the mail yesterday Very happy so far with the quality, but haven't made any parts on it yet. Gonna keep an eye on the monthly specials page for their 3inch 4 jaw chuck.
  1. G0704 extended Y axis??
    By Jim27 in forum Benchtop Machines
    Last Post: 12-26-2014, 03:11 AM
  2. G0704 5th axis
    By outsider787 in forum Benchtop Machines
    Last Post: 12-14-2012, 01:04 AM
  3. G0704 Z-axis Disassembly
    By Titaniumboy in forum Benchtop Machines
    Last Post: 10-11-2012, 07:26 PM
  4. G0704 X axis conversion
    By pemko in forum Benchtop Machines
    Last Post: 02-28-2012, 03:07 AM
  5. New G0704, need 2 or 3 axis DRO kit?
    By wildonewest in forum Benchtop Machines
    Last Post: 12-31-2010, 05:23 PM
