586,408 active members*
2,901 visitors online*
Results 1 to 6 of 6
    Nov 2014
    12
    Tooling for PCNC 770 build
    To continue to PCNC 770 build as discussed here ...
    We were debating metric vs imperial. Posts 6, 7, & 8 are illuminating.
    In summary, the main advantage of metric is the ease of base-10 math.
    While the advantages of imperial include availability and price.
    Questions:
    1. Just to be clear. I can design in CAD in metric and the CAM software will automatically "adjust" for imperial tooling?
    2. I'll be cutting aluminum mostly. Are there desirable brands, materials, and coatings and ones to avoid?
    Thus far tool holding and Tormach tools these items are on my list:
    Tool Holding
    32284 CNC Operator's Set (or metric 32291) $795.00
    30233 TTS-MT3 Collet & Drawbolt $29.76
    Tools
    31807 Modular Tension / Comp Tapping Head Kit $345.73
    33031 TTS SuperFly Cutter Kit $148.50
    32447 TTS Diamond Drag Engraver Kit $68.79
    32452 90* Replacement Diamond Dragger Bit $23.99
    32453 120* Replacement Diamond Dragger Bit $23.99
    $1,435.76
    As the decision to go metric or imperial has not been finalized, the long list of possible cutting tools include ...
    MSC Industrial Supply
    End Mills
    Metric
    $ Size Shank Reach Flutes Corner Rad Material Coating Brand Order #
    33.49 2 6 15 2 0.20 Carbide Accupro 93161586
    32.51 4 6 15 2 0.25 Carbide Accupro 93161644
    32.51 6 6 16 2 1.00 Carbide Accupro 93161719
    50.04 10 10 25 2 1.00 Carbide Accupro 96161768
    148.55
    Ball End Mills
    Metric
    21.43 1.5 3 6 4 Carbide TiCN Accupro 1217819
    23.14 4 4 14 4 Carbide TiCN Accupro 1217868
    28.69 6 6 19 4 Carbide TiCN Accupro 1217892
    53.74 10 10 25 4 Carbide TiCN Accupro 1217934
    127.00
    Chamfer Mills
    Metric
    59.88 8 8 4 Carbide SIRA Seco 81019226
    Drill Bits
    Metric
    $ Size Angle Material Coating Brand Order #
    73.60 1-10 by 0.5mm 118 HSS Oxide Hertel 07574932
    175.60 1-10 by 0.5mm 118 HSS TiN Dormer 80980840
    Tap & Die
    Metric
    $ Size Material Coating Brand Order #
    104.25 M3-M12 HSS Bright Hertel 59337535
    175.20 M2.5-M12 HSS TiN Hertel 88244215
    McMaster Carr
    End Mills
    Metric
    17.69 2 3/16 6.4 2 HSS TiN 8694A12
    16.86 4 3/8 11.1 2 HSS TiN 8694A16
    17.18 6 3/8 12.7 2 HSS TiN 8694A21
    20.51 10 3/8 20.6 2 HSS TiN 8694A27
    72.24
    13.85 2 3 6.3 2, 3, or 4 Carbide TiN 8866A231
    17.76 4 4 14.0 2, 3, or 4 Carbide TiN 8866A271
    21.67 6 6 19 2, 3, or 4 Carbide TiN 8866A321
    37.45 10 10 22 2, 3, or 4 Carbide TiN 8866A361
    90.73
    Drill Bits
    Metric
    60.67 1-10 by 0.5mm 135 HSS Black & Gold 30155A55
    110.38 1-13 by 0.5mm 135 HSS Black & Gold 30155A57
    73.08 1-10 by 0.5mm 118 HSS Bright 30555A64
    105.08 1-13 by 0.5mm 118 HSS Bright 30555A66
    Tap & Die
    Metric
    189.23 M3-M12 HSS 2646A14
    Kodiak Cutting Tools
    End Mills
    Metric
    10.37 2 3 6.3 4 Carbide Kodiak 133769
    12.78 4 4 14 4 Carbide Kodiak 133813
    16.33 6 6 19 4 Carbide Kodiak 133846
    34.09 10 10 22 4 Carbide Kodiak 133890
    73.57
    End Mills
    Imperial
    Kit
    1/8 1/8 2 or 4 Carbide ALTiN Kodiak 2 flute
    3/16 3/16 2 or 4 Carbide ALTiN Kodiak 6I-RY3N-FNED
    ¼ ¼ 2 or 4 Carbide ALTiN Kodiak
    5/16 5/16 2 or 4 Carbide ALTiN Kodiak 4 flute
    3/8 3/8 2 or 4 Carbide ALTiN Kodiak F6-78KG-DBQ3
    ½ ½ 2 or 4 Carbide ALTiN Kodiak
    99.99
    End Mills
    Imperial
    21.77 5/64 1/8 6.4 4 0.015 Carbide TiCN Accupro 58736374
    26.62 3/16 3/16 15.9 4 0.02 Carbide TiCN Accupro 86642931
    34.51 ¼ ¼ 19.1 4 0.03 Carbide TiCN Accupro 86769775
    44.22 3/8 3/8 22.2 4 0.06 Carbide TiCN Accupro 87829222
    127.12
    McMaster Carr
    End Mills
    Imperial
    14.84 1/8 1/8 12.7 4 0.015 Carbide 30705A11
    19.87 3/16 3/16 15.9 4 0.02 Carbide 30705A17
    24.20 ¼ ¼ 19.1 4 0.03 Carbide 30705A26
    38.65 3/8 3/8 25.4 4 0.045 Carbide 30705A46
    97.56
    Kit
    1/8 3/8 2 HSS TiCN 88505A34
    3/16 3/8 2 HSS TiCN
    ¼ 3/8 2 HSS TiCN
    5/16 3/8 2 HSS TiCN
    3/8 3/8 2 HSS TiCN
    ½ ½ 2 HSS TiCN
    104.54
    Kit
    1/8 3/8 4 HSS TiCN 88505A43
    3/16 3/8 4 HSS TiCN
    ¼ 3/8 4 HSS TiCN
    5/16 3/8 4 HSS TiCN
    3/8 3/8 4 HSS TiCN
    ½ ½ 4 HSS TiCN
    128.33
    Chamfer Mills
    Imperial
    37.72 3/8 3/8 4 Carbide 3073A67
    Apr 2013
    1788
    Re: Tooling for PCNC 770 build
    In most (if not all) CAM software one gives the diameter of the cutter. Consider that every imperial sized cutter is not "dead on" and you may want to tell the CAM to assume a 0.249 diameter cutter rather than 0.25000. When working with metric parts some CAM systems may require that you define a 1/4-endmill as 6.35mm but that is normally done once when setting up the tool database.
    It isn't clear from your price list but I would never order only one of any size of endmill. There is nothing worse than trying to complete project on Saturday afternoon and break the only proper sized cutter in inventory. My usual approach is to never order less than 3 cutters of a particular size. Some suppliers offer discounts when purchasing 5 or 10 of a single size.
    You should carefully consider the Tool Assistant 32284 kit since you will probably never use some of the items in it. Unless you plan to use Weldon style cutters the setscrew holders don't properly grip endmills. I haven't done the sums but there may be sufficient discount that the setscrew holders are "free". I also don't like the Tormach keyed drill chucks that are in the kit since a key is required to change the bit. I greatly prefer a keyless Albrecht chuck. Or even better, use an ER collet to hold drill bits. You will probably also want a set of metric ER20 collets since the collets in the kit don't cover the full capability of ER20 holders. Either get a Tormach 32306 collet set or pay half as much and get two sets from CTC (CTC Tools Home Page ). You will probably soon decide that you need more holders too!
    Rather than the digital height gage in the kit, the money might be better spent on a Tormach 31875 tool setter. I haven't bought one yet and there are other vendors that are considerably cheaper. Just something for your consideration since the height gage + granite plate is about $250 and is less convenient to use.
    Jul 2004
    1424
    Quote Originally Posted by kstrauss View Post
    Matter of personal preference. I prefer to use the endmill holders instead of collets... but than all of the endmills I have do have "weldon flats" on them to allow the setscrew to hold. If you go wander around a professional machine shop, you will find a lot more end mill holders than ER style collets.
    Just a note on MSC-Direct. Their normal prices are insanely high. Their sale prices are what most other places charge as normal. Every few weeks they have a sale, frequently like "UP TO 45% off metalworking". They key words are "UP TO", as you won't get that kind of discount on everything, and stuff already on sale doesn't get discounted. They are the choice of professional machine shops because you can get your order the next day. Even if you order on a Sunday.
    Bottom line: NEVER order from MSC Direct unless you are buying something on sale. They do have a good selection of cutting tools, however.
    If you are buying HSS and carbide endmills, I prefer to go to Enco (which, strangely enough, is owned by MSC Direct). They had a 20% off sale that ended a couple days ago, but don't worry, such sales happen every 3-4 weeks. Fill up your Enco shopping cart between sale, and when the sale coupon comes out, press BUY.
    Another good place to buy is CarbideDepot. Or MariTool.
    +++1
    There are many ways to skin this cat, but I find granite block + height gage much less convenient than just zeroing each endmill while chucked up in the mill (which will automatically record the endmill height offset in the tool table).
    Tim
    Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
    Feb 2006
    7063
    I use set-screw holders all the time on tools with no Weldon flats, and I've never once had one move one bit, even on the most aggressive cuts.
    Regards,
    Ray L.
    Jun 2008
    1082
    To answer your main question (and to reiterate a little): yes, any CAM program that's worth a **** will let you use both imperial and metric tools. The reason for that is: "they" really can't stop you. Converting between inches and mm is exact. A 1/4" cutter IS a 6.35mm cutter*. Those two numbers may be written differently, but what they represent is exactly the same. I think it's worth noting that you will not enter "1/4" into the CAM program's tool table, you'll enter "0.25". I only mention that to make light of the fact that both numbers (0.25 and 6.35) have two significant digits following the decimal place. Also, the CAM program isn't going to care if the numbers following the decimal point are all zeros or are all different. Sure, some conversions won't work out so perfectly, but most (all?) CAM programs will let you stretch your tool measurements out to at least four digits past the decimal when working with imperial units or three digits with metric. Anything beyond that would be basically meaningless when talking about milling... I mean, it's hard enough to accurately *measure* differences that small, it's not worth it to worry about them in the tool table.
    * you could also call it a "~0.0139 cubit" cutter if that's what you're into.
    The diameters of the bits are the diameters of the bits. The CAM program isn't going to care what you use to measure them as long as you convert your units into units it can understand.
    Conversely, the marked size of the cutters aren't exact, as kstrauss mentioned. Take a "3/16in" end mill for example. The decimal equivalent of 3/16" is 0.1875". The metric equivalent is 4.7625mm. That "3/16" bit might be undersized by a "tenth" (0.0001") or two. The actual diameter might be 0.1874". Well, oddly enough, the rough metric equivalent of that is 4.76mm. There, you've saved yourself two significant digits... not that it matters. Similarly, take a "5mm" end mill and measure it with a micrometer. It's probably going to be a tenth or two undersized as well. Suddenly your "5mm" end mill is actually 4.995mm.
    Basically, all I'm trying to say is that the numbers etched into the side of the end mills you buy are just a number. As long as the CAM program is given an equivalent number that it can understand: you'll be fine. You might be wondering "well, why go with imperial then?". The answer to that is simple enough: imperial tool holders (collets, in particular) are readily available. A 1/4" collet will hold a 6mm end mill, but not perfectly. It'll hold a 1/4" end mill a little better. You could probably shove a 5mm end mill into a 3/16" collet, but it probably wouldn't hold it properly. A 13/64" collet would work OK for a 5mm end mill, but 13/64 is an oddball size that you're less likely to have on hand and it's less likely that they'll be available locally.
    Jul 2004
    1424
    Quote Originally Posted by tmarks11 View Post
    And there it is:
    Quote Originally Posted by ENCO
    20% OFF with promo code: 20WED through 11pm ET on 01/14/15.
    15% OFF with promo code: 15THUR through 11pm ET on 01/15/15.
    10% OFF with promo code:10FRI through 11pm ET on 01/16/15
    Tim
  1. Tooling for Tormach PCNC
    By thuss in forum Tormach Personal CNC Mill
    Last Post: 04-04-2013, 09:01 AM
  2. Replies: 4
    Last Post: 05-07-2012, 12:54 PM
  3. CNC diemaking shop needed to build tooling from my SolidWorks models
    By PhoenixMetal in forum Diemaking / Diecutting
    Last Post: 01-19-2011, 04:15 PM
  4. Help me build a tooling list
    By RP Designs in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2009, 03:23 AM
  5. Discussion: Using aluminum tooling plate to build a bridge mill.
    By Deviant in forum Uncategorised MetalWorking Machines
    Last Post: 08-11-2006, 07:18 PM
