Originally Posted by
aaroncaw
Looking for help solving an ongoing problem with many of our Haas machines. Over the last 2 years our company has replaced about 20 vector drives to the tune of $2700.00 each! The alarms produced are all related to either Low DC voltage, Shorted DC buss etc because the control doesn't see the required 325Vdc buss for the servo drives at the correct level. The problem occurs after the machines have been powered off over a long weekend. All the "tests and checks" required by Haas shows nothing wrong. All voltage levels are correct, no drives are shorted, the only problem is that the signal coming from the Vector Drive itself is not accurate, or takes a very long time to reach a level that the control finds acceptable. If the level is watched (in diagnostics) and it rises above 300VDC, a "quick power cycle" can be performed and the machine comes up alarm free and will run absolutely fine until the next time it is powered down for longer than an hour. In all the cases we have replaced the drive, it was due to a concern that the machine will go down at a critical time and the replacement part will not be on our shelf. I have contacted Haas and they have acknowledged the fact that the problem is as a result of a component failure in the drive. Upon examination of our last failure, I found a small capacitor on the Power PCB inside the drive had burnt/failed. A simple 29 cent parts failure cost our company $2700.00 AGAIN!! Apparently this board ( that Haas Automation stamped on it ) is not available from Haas. I am looking for anyone who can help with suggestions for alternatives to replacing the entire drive. I would think that a company that prides itself on customer service would provide a more cost effective solution to customers who have over 200 of their machines.
