586,065 active members*
4,570 visitors online*
IndustryArena Forum > CAD Software > Solidworks > Using diameter instead of radius? + Multiple instances of the program?
Results 1 to 10 of 10
    Nov 2010
    65
    Hi all.
    I have 2 questions.
    Is it possible to configure SolidWorks so that I can input diameter instead of radius when making a circle in the Sketch environment when making a part? How do I do it?
    Is it possible to run several instances of the software, so that I can have one instance open on each of my monitors? This was possible in other 3D software I tested, but for some reason SolidWorks wont let me.
    Jul 2010
    46
    Re: Using diameter instead of radius? + Multiple instances of the program?
    Quote Originally Posted by Lene Madsen View Post
    Hi all.
    I have 2 questions.
    Do you mean when you're doing a revolve feature? Use a center line to produce a doubled dimension.
    I can open multiple instances with no problems. Which version are you using?
    Jun 2008
    562
    If you are using "screen input", in the circle dialog property manager there is a check box for "diameter dimension". That should set all future circle dimensions to diameter in sketch mode. I am set up to "auto show property manager"
    Mike
    Nov 2010
    65
    Thank Mike. I will try that.
    I am using version 2015. Is it a setting to allow multiple instances?
    Jun 2008
    562
    Mike
    Feb 2009
    311
    Hi all.
    Why do you need to have two instances of SW running? I only use one monitor but I'm pretty sure you can have SW display on both monitors.
    C|
    Nov 2010
    65
    Quote Originally Posted by cygnus x-1 View Post
    C|
    It does spread over 2 monitors, but that leaves you with all menues on one screen. Also it's a problem since my monitors are not alike and the software fits itself to the monitor with the lowest resolution, which is logically my secondary screen.
    Nov 2010
    65
    I found out it can actually run two instances, although the second one to be opened does not work with autorecovery in case of crash, but atleast I can have a document open on the other monitor for viewing.
    Yes Mike, it does allow me to input diameter how you explained. Thank you.
    Lene
    May 2007
    312
    Please post a screen shot, I cannot find that check box we are up to 2015 sp2 and have never seen that option, auto show is checked.
    Quote Originally Posted by Mike 1948 View Post
    Mike
    Nov 2010
    65
  1. select multiple instances of same part
    By Andrew D in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-21-2013, 03:38 AM
  2. B&O Fanuc 6t radius to diameter
    By twebster1024 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-25-2012, 06:04 PM
  3. Radius vs Diameter program reading
    By botha.y in forum SIEMENS -> GENERAL
    Last Post: 02-16-2012, 08:36 PM
  4. Lathe Diameter or Radius
    By davidperry3 in forum Tormach Personal CNC Mill
    Last Post: 12-24-2009, 06:18 PM
  5. From Radius to Diameter Programming
    By metx in forum Fanuc
    Last Post: 04-10-2008, 07:04 PM
