Do you have the parameter manual that is set up in sections? e.g. Parameters related to Feedrate etc?
If you took the parameters from a hardcopy, it is possible it was changed in the control and no one changed the copy.
It is going to be only the parameters that affect individual axis.
For futere You should be able to upload and download through the RS232 port if you have one.
Al.
Albert E.
