586,069 active members*
3,454 visitors online*
    Feb 2008
    20
    Mach 3 E stop problem
    Hi is there any one who has come across this problem.
    When the E stop is activated the motors are armed and power is sent to the boards (you can actually hear the pitch of the electronic noise on the motors) but the motors can't run because of the e stop if the stop is cleared the power to the motors is lost but the Dro Still operates ?
    24221
    Re: Mach 3 E stop problem
    Sounds as though the E-Stop wiring has not been done correctly, main power removed from all motors and Mach advised via the E-stop input pin.
    Al.
    Albert E.
  1. Random E-Stop on Mach?
    By ssutton in forum DIY CNC Router Table Machines
    Last Post: 12-14-2013, 11:15 PM
  2. I/O Functions and hard stop homing for Mach 3
    By Dr.Nos in forum CNC Machine Related Electronics
    Last Post: 09-26-2013, 10:47 PM
  3. Exact stop vs cv mode in Mach 3 from sheetcam
    By drieslaas in forum SheetCam
    Last Post: 06-30-2012, 09:37 AM
  4. Replies: 5
    Last Post: 12-31-2011, 02:29 AM
  5. Mach 3 Start, Stop Buttons
    By grandpa jay in forum Mach Mill
    Last Post: 10-18-2011, 01:55 PM
