586,069 active members*
3,410 visitors online*
    Aug 2013
    21
    TB6560 problems
    I've just bought a TB6560 breakout board after my old breakout board burnt out. When I connected up my new breakout board and powered it up the fan isn't running and the stepper motors don't lock up ready to run. I've checked the voltage going into the board which is set up to 36DCV for my nema 34 stepper motors and all the wiring looks good but. Any advice.
    Dec 2007
    2134
    Re: TB6560 problems
    If the previous board was working and this one without anything being changed isn't, then it looks like your suffering from any of the myriad issues revolving around the various designs of boards using this driver IC. Generally most of the all-in-one TB6560 based boards on ebay simply will not work properly, or even not at all depending on the particular board revision.
    There's several very large threads here you'll easily find regarding what people did to get theirs going, usually requiring minor to major circuit reworking.
    Myself, I think they are a complete waste of money, and even when working still perform like a bag of crap compared to any of the decent drivers available. I lost several painful months with my 6040, until I finally admitted it wasn't worth it, and replaced it with a G540.
    The acknowledged issues with these are not a matter of opinion, the crap PCB design, dodgy buffering/isolating, earthing and ground issues, and peculiar power up/down sequences that it requires to avoid blowing the IC's, are well documented.
    cheers. Ian
    It's rumoured that everytime someone buys a TB6560 based board, an engineer cries!
    Dec 2014
    30
    Re: TB6560 problems
    The maximum recommended supply voltage is 34V for -30 to +85 degree C although the stated max. is 40V at 25 degree C.
    I think some jumper settings are wrong...read the operating documents if any are supplied. Post a sharp 12 o'clock
    above picture if you can of the board here.
    1695
    Re: TB6560 problems
    Sounds like a bad board, since even the fan doesn't run.
    Dec 2014
    30
    Re: TB6560 problems
    Did the power led light up? If you know how to use a multimeter check if there is 5 volts Dc or some other voltage like for the relays present.
    If they are present then the board has the voltage for the control circuit. Since you say the motors don't lock up then it's obvious the motors and the
    controller board is not getting the correct operating power. Have you wired it correctly? Check the wiring of the machine
    is it broken/open circuit somewhere.Your multimeter can check this by using the beeper/continuity/diode test function.
  1. TB6560, Ubuntu, and EMC2 Problems
    By ajbeck in forum LinuxCNC (formerly EMC2)
    Last Post: 03-26-2014, 01:13 AM
  2. TB6560 the board with ever occuring problems!
    By dan_n_e in forum CNC Machine Related Electronics
    Last Post: 01-27-2014, 05:38 PM
  3. TB6560 v2 problems..
    By sky120 in forum Stepper Motors / Drives
    Last Post: 07-25-2013, 09:42 PM
  4. Another one who has problems with TB6560 in Mach3 :)
    By MLadegaard in forum Mach Software (ArtSoft software)
    Last Post: 10-01-2012, 09:00 AM
  5. TB6560 problems, help?
    By skyguynca in forum Momus Design CNC plans
    Last Post: 09-29-2012, 05:19 AM
