586,692 active members*
3,052 visitors online*
Thread: TL1 CRASHED
    Oct 2007
    31
    Angry TL1 CRASHED
    CAN ANYONE TELL ME HOW TO LINE THIS TL1 BACK UP ? WHERE DO YOU START????
    IT IS CUTTING .015 TAPER IN 10 INCHES IN Z AND .009 IN 5 ON X
    Oct 2007
    31
    Re: TL1 CRASHED
    OOPS IT IS A TL2
    Jul 2005
    12177
    Re: TL1 CRASHED
    It sounds like you have moved the headstock. You can check whether the face of the chuck is parallel to the X axis using an indicator, and you will probably find it is out the same as your X taper.
    I crashed my TL2 and moved the headstock and simply loosened the big bolts holding it to the base and then tapped it until I had it cutting within about 0.0005" in 6" on the Z axis.
  1. Cnc Crashed
    By Buffoni33 in forum Uncategorised MetalWorking Machines
    Last Post: 05-24-2014, 11:14 AM
  2. Crashed VF3
    By Eric MFG in forum Haas Mills
    Last Post: 04-09-2012, 11:20 PM
  3. EC2.3.5 Crashed
    By erlyrisa in forum LinuxCNC (formerly EMC2)
    Last Post: 07-29-2010, 06:50 AM
  4. Crashed Our VF-2 Need help
    By DaOne in forum Haas Mills
    Last Post: 04-20-2009, 08:24 PM
  5. SMTC crashed
    By JPMach in forum Haas Mills
    Last Post: 03-17-2006, 02:16 AM
