586,089 active members*
4,037 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Driving me insane. RoboDrill T10b alarm 252 only after machine has been sitting
Results 1 to 6 of 6
    Sep 2014
    22
    This only started happening about 2 weeks after changing the spindle motor,
    after the machine has been turned off over night. in the morning they will turn the spindle on and warm up the machine. when they go to do the first tool change Alarm 252 comes on (ATC spindle 252)
    the manual says to check on Diagnosis bit 531, if bit 6 is 1 then there is a deviation in magazine index.
    if bit 2 is 1 then there is a deviation in spindle movement. this is the Bits that i got: 01100100,
    6 and 2 are on! after i do a turret restoration after the alarm it will make tool changes fine and sometimes in the mornings it wont even alarm out!
    i called Methods Machine and spoke to Michael said that this is strange and would have to have a tech sent out to take a look at it. which i really dont want to do.,.
    any leads on this or advice would be appreciated.
    Sep 2014
    22
    Re: Driving me insane. RoboDrill T10b alarm 252 only after machine has been sitting
    ended up turning the turret spin speed down. and problem is solved.
    only thing i can think of is in the mornings and the machine and bearings being cold. it is throwing the alarm because there is some slight resistance in the turret.
    slowing it down by 50% really helped. and its not as scary either!!
    May 2014
    4
    Hello, i have the same problem, may you tell me how to turn down the speed? I apreciate your help, thanks
    Sep 2014
    22
    Quote Originally Posted by Eriksanchez View Post
    What's your e-mail? I will send you the parameter list that Methods gave me and info in it.
    Jul 2015
    I have the same problem here and we change the spindle motor last month. Can I have your document please or just say which parameter is
    Thank for your help
    Apr 2023
    Quote Originally Posted by NoGoodNolan View Post
    Hello, did you ever figure out the real reason for this alarm? I'm having the same issue..
  1. Fanuc Robodrill t10b problem. 16m controller
    By NoGoodNolan in forum Fanuc
    Last Post: 02-26-2019, 04:35 AM
  2. 252 ATC alarm robodrill T14iA
    By jorgehrr in forum Fanuc
    Last Post: 07-28-2015, 08:07 PM
  3. Home switches in EMC2...DRIVING ME INSANE
    By neity in forum Benchtop Machines
    Last Post: 06-21-2012, 06:20 AM
  4. Maintenance on a sitting 1 1/2 yr old SX3 machine
    By idtkid in forum Syil Products
    Last Post: 05-22-2009, 08:44 AM
  5. Robodrill T10-a/911 Alarm
    By osomaker in forum Fanuc
    Last Post: 12-28-2006, 07:11 AM
