586,082 active members*
3,650 visitors online*
Results 1 to 13 of 13
    Apr 2008
    23
    okuma 5020 5000
    hello does anyone know how to turn on the lap function on a osp 5020, osp 5000 lathe
    thank-you
    Feb 2009
    6028
    Re: okuma 5020 5000
    You mean program it? Lap was not something you turned on or off, simply programmed it.
    Apr 2008
    23
    Can you give me a sample working program that I can test on machine thanks
    Apr 2008
    23
    I found an example and all I get is 512 Alarm-B LAP no spec
    Feb 2009
    6028
    Re: okuma 5020 5000
    Quote Originally Posted by jim2970 View Post
    as far as I know, all the 5020l's had basic LAP cycles. If you are using the std G85 LAP roughing cycle, and it says no spec like that, it would require new software and re-load to get it. Probably not worth that kind of money.
    Attached Thumbnails Attached Thumbnails G85.pdf
    Apr 2012
    15
    Re: okuma 5020 5000
    Try this:
    G90 G50 S2000
    NBT08 G95 G97 S152 T0808 M03 M08 M42
    ( TOOL #8 - 15 DEG. LEAD ANGLE TURN )
    ( USE_SNMG-543 MR7-TP40 )
    NB40 (ROUGH TURN)
    G00 X8.8 Z.5
    Z.1018
    G96 S350 G111
    G85 N15 D.27 F.015 U.02 W.003
    N15 G81
    G00 X8.5396
    G01 Z-.0232
    X8.606 Z-.0564
    Z-.675
    X8.8
    G80
    G97 S155
    G00 X30. Z30. M05 M09
    Apr 2008
    23
    Tried it still get same alarm 512 Alarm-B LAP no spec
    Was hoping it was just a hidden parameter change
    Apr 2012
    15
    Re: okuma 5020 5000
    I'm guessing you don't have user task 2 that is why it doesn't work. I have a couple of okuma lathes that don't have it so I can't used the canned cycles.
    Apr 2008
    23
    Do you know how to get that added
    Apr 2012
    15
    Re: okuma 5020 5000
    That would be software, so you'd have to go to your dealer.
    Feb 2009
    6028
    Re: okuma 5020 5000
    Yep, no lap option then. Would probably end up being cheaper to buy a computer and CAM software then getting the software and getting it loaded. Maybe we should start a pool on how much overpriced Okuma will be. Im guessing $4K for the software and 1K for the service call.
    Aug 2011
    2517
    Re: okuma 5020 5000
    we should start an archive of software. I backed up all my floppies (3 1/2" for OSP7000) a year ago.
    Aug 2011
    419
    Re: okuma 5020 5000
    What about lap function of cnc?
    "Imagination is more important than knowledge."
  1. OKUMA OSP 5020 GRAPHIC VERIFY?
    By hoganj in forum Okuma
    Last Post: 09-22-2014, 03:13 PM
  2. Okuma 5000/5020 12" monitor LCD replacement and more
    By monitor_guy in forum For Sale Only
    Last Post: 01-13-2014, 06:42 PM
  3. Replies: 0
    Last Post: 06-13-2010, 04:03 AM
  4. Okuma GKN 5020 Automatic Door Modification
    By ceilingwalker in forum Okuma
    Last Post: 05-22-2010, 08:33 AM
  5. okuma lt 15 m 5020 newb question
    By fabshop in forum Okuma
    Last Post: 04-30-2009, 06:18 PM
