Attachment 264368
Attachment 264370
Attachment 264372
TOPCNC Automation Technology - Small Orders Online Store, Hot Selling cnc plasma cutters for sale,cnc cable,cnc control box and more on Aliexpress.com | Alibaba Group
Product Introduction
TC55V stepper/servo motor controller is an upgrading version of TC55. It is equipped with 3.5 inch color screen, RS 485 communication, Chinese/English Switch, encoder input, and USB connection. It is highly reliable, highly accurate, low noise and easy to use.
Main Functions
Automatically execute:Actual running, Dry running, Single-step execution, Terminate program, Start and Pause function
Manual operation:Manual high speed, Manual low speed, Jog operation, Back to program zero, Back to machine zero
Program management:absolute programming, Incremental programming, linear and circular interpolation, back to machine zero, sub-program call,register, delay, repeat, Output, PLC set, Pause
Parameter settings:Set various control parameters of processing and operation, get the best status of processing effect
Exterior Manual Operation: control motor clockwise and counter-clockwise spinning, Start, Pause, Alert and Emergency Stop.
USB Connection and upgrade
PLC Extension
I/O Extension
Isolated I/O port
Chinese/English panel display
Free change of boot picture
Technical Specifications
Minimum data unit 0.001 mm
Maximum data size ± 99999.999mm
Maximum Speed: 9000mm/min (pulse is 0.001mm)
Maximum pulse output frequency 150KHz
Axis 1-4 (X,YZ,C)
X,Y,Z,C axis can conduct linear interpolation, X,Y can do circular interpolation.
Electric Gear: numerator :1-99999 denominator: 1-99999
System main functions are automatic, manual, program editing, system parameters, self-check, settings, etc.
Size
Outside Size 172×94×48mm
Installing Size: 162×84mm,Front Panel: 4mm
Contact:
[email protected]
Skype: feliciajia19861229
whatsapp: +8613811674107
