586,036 active members*
3,817 visitors online*
    May 2006
    89
    "tool slot number too large" code
    Help! I have an error code that says " selected tool slot number too large on line # 5 ". I am pocketing a slot .250" wide .300" deep 1" long with a .187" dia. cutter. I have reduced the stepover to .001" and even tried a .030" cutter but it still gives me this code. What does this code mean?
    Exotic Welder
    May 2006
    89
    problem solved
    I just restarted everything and the problem went away. I also got a very quick response from the Mach support they are good.
    Exotic Welder
