586,061 active members*
4,358 visitors online*
Results 1 to 6 of 6
    Oct 2011
    477
    Blue Way Lube
    Was in a shop recently and noticed that the machine oilers were filled with a bight blue way oil. The oil was almost neon cobalt blue. Explanations was that they have gone to a color coded oil system to help prevent the wrong oil in the wrong hole epidemic (machine tool Ebola).
    Apparently, way oil has found it's way no spindles, hydraulic oil into way lubricators, etc.
    Anybody know here this stuff comes from? May not work any better than anything else but it looks cool and you could see the blue film on the surfaces.
    Mar 2006
    36
    Re: Blue Way Lube
    I would buy it. I also would like to know if the oil is getting to where it is supposed to be.
    Oct 2011
    477
    Re: Blue Way Lube
    Exactly my thinking also.
    Jun 2006
    3063
    Re: Blue Way Lube
    Is it possible that they just added some sort of dye to the way oil? Mobil or one of the other way oil manufacturers might be able to suggest a suitable dye, if one exists. Mobil was quite helpful a few years back when I was looking for modern equivalents to the lubes recommended in the 40+ year old manual for my Clausing lathe.
    Mike
    Jul 2010
    46
    Blue Way Lube
    The lube system in our flow water jet uses a bright blue Mobil lube - not sure if it's suitable as way oil or not.
    Edit: Just looked it up - Mobile XHP-005 NLGI00
    Sent from my iPad using Tapatalk
    Feb 2009
    6028
    Re: Blue Way Lube
    As long as its a true way oil, and not one of those Eco friendly oils you can use as coolant should be OK.
  1. What is this blue cloud?
    By NewHobby in forum BobCad-Cam
    Last Post: 12-08-2013, 09:41 PM
  2. Blue Screen mostly black instead of blue
    By turmite in forum Screen Layouts, Post Processors & Misc
    Last Post: 07-01-2013, 10:27 PM
  3. Replies: 3
    Last Post: 03-04-2012, 10:42 PM
  4. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  5. IH Blue Formula
    By IHCNC in forum Charter Oak Automation Support Forum
    Last Post: 02-18-2008, 11:28 PM
