I've been reading up on this, making an MDF vacuum holddown bed. One with no holes in it, where the air infiltration through the MDF itself is enough for the vacuum effect. Which I have trouble believing, honestly, but that's what people told me and DIY info online shows working.
I'm a little unclear on a few points-
If I use "ultralight" MDF, does both sides still need to be surfaced? MDF is faced with invisibly sealed face surfaces that don't allow air to pass. I'm not sure if that applies to the "ultralight".
How deep does the vacuum bed's grid get cut, and what's width and spacing? Was that one sheet of MDF or did 2 get glued together to get the required thickness before cutting the channels?
What's the practical solution for facing MDF? I have 1/4" endmills here. I've seen some people advertising MDF fly cutters but they seemed mighty expensive. Otherwise, the math is self-evident- with 50% stepover at say 200 ipm, that's 5.76 min per sq ft. 3 hrs for a pass over 4x8. Which isn't impossible but the time sounds like a thing.
Most important:
Is it essential to glue down the MDF bleeder board? It sounds like the vacuum would hold it anyhow. I can't be sure how often this will need replacement. Cutting off the original one sounds like a big thing. I can easily picture a screw-up where someone drives the bit right through just one part of that bleeder board. It may be cost-effective to save it by gluing in a plug and having access to the bottom of the sheet would certainly help.
How much vacuum do we lose if the entire bleeder board area isn't covered?
