This seems like a simple question, but I'm stumped!
I'm cutting a piece larger than the table (Tormach 770). When using the waterline operation I set a restrict zone for the area off the table and Sprut does the right thing.
Now I'm trying to get the Drive ops and Pocketing ops to work the same way, but they don't have the job zone or restrict zone features for these ops. For the Drive op, I'm using "add faces" to define the areas to cut, but some faces cross outside the table area. For pocketing ops I use "add pocket" for those that fit within the table, but the same problem occurs when pockets cross outside the envelope.
Is there a Job/Restrict zone for these ops?
Is there a way to "split" faces so I can define the areas to cut more precisely?
Thanks!
--Bryan
