586,065 active members*
4,638 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Bad ball screw nut or bad bearings?
    Sep 2006
    296
    https://www.youtube.com/watch?v=1hRq...ature=youtu.be
    Listen to the video and tell me if you have heard this before. Is this a bad ball screw nut, bad thrust bearing or support bearing?
    Jul 2005
    12177
    Re: Bad ball screw nut or bad bearings?
    I cannot answer your question despite having a VF0 that made the same noise when doing a rapid on the X axis. I hauled off all the covers and tried to identify which it was even using an engine stethoscope without any luck; the noise just seemed to come from everywhere. So I checked positioning and repeatability, and concentricity when doing circular interpolation and everything was fine and within specs. So we limited to rapids to 50% just to cut the noise and used the machine for another three years without any problems.
    If your machine is still turning out good parts my advice is to wear ear plugs if the noise bothers you rather than spend several thousand dollars.
    Feb 2010
    1184
    My money is on the thrust bearing!
    I have heard that sound many many times.
    Sep 2006
    296
    Thats what i was hoping to hear.
    Feb 2010
    1184
    Quote Originally Posted by GITRDUN View Post
    No guarantees mind you, but at least if the new thrust bearing does not fix it, it can still be used on X,Y or Z if/when one does go out.
    Good luck and be sure to report back.
  1. backlash with new bearings and ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 07-23-2012, 05:22 PM
  2. Bmc ball screw support bearings
    By JWC in forum HURCO
    Last Post: 09-27-2008, 03:56 PM
  3. installing ball screw bearings
    By dgalaxy in forum Bridgeport / Hardinge Mills
    Last Post: 09-01-2006, 03:06 PM
  4. Ball screw without bearings?
    By Halfnutz in forum MetalWork Discussion
    Last Post: 06-13-2005, 09:10 PM
