Pro red line laser alignment is just the most advanced and most affordable line measurement tool. It emits highly visible red laser beam from import 635nm red laser diode. Usually it has much brighter beam emitting than 650nm red laser with same output power range.
Combined with its special light emitting mode of non gauss light emitting, this red laser alignment always gets super wonderful line emitting with high line straightness and high beam visibility. In long distance line generation working fields, its visible red laser beam still maintains uniform light emitting as well as high fineness. Whatever kind of industrial line measurement working fields, this industrial alignment laser always makes high quality line generation. It adopts constant current electric circuit board, thus it can always assure super stable line emitting. Its internal red laser diode is always in the best working condition in long time continuous line generation.
Technical Data:
Name: Berlinlasers Pro Red Line Laser Alignment
Light Emitting: Non gauss light emitting (uniform distribution line emitting)
Wavelength: 635nm
Output power: 5mW – 100mW
Serving Lifetime: 8000 hours
Warranty period: 180 days
Application: textile cutting and positioning, wood board processing, stone cutting, laser cutting, precise machinery processing
