586,584 active members*
2,651 visitors online*
    Sep 2006
    34
    I want your opinion - XYZ Table
    hello from Greece...!
    Sorry for my Bad English....
    I design a XYZ table
    I want to build A CNC machine to use it for doming decals / Doming Scripting
    Every thing you see is from Bosch Rixford Except the Y and Z frames
    The Y and Z I want to be milling Alluminium...
    If You interest I would like to post the Designs of the Y And Z...
    Is very detailed But I was design them In Adobe Illustrator (I work this programme for 10 years now And is very easy for me to Design and messure.
    The table size is About 100cm X 80cm
    I use Alluminium Profiles
    45X45
    45X90
    40X120
    I Want Servo motors because I want very high Percision
    Also Iwant your Advice If You Like ...
    1) What do you think about my design?
    2) What motors do you think is best for this table?
    3) What size of Ball Screw You think is the best for this size of table?
    4) Is this Company familiar to you? http://www.lowcostcncretrofits.com
    Please help the new boy.
    :drowning:
    George Toubalis
    Graphic Designer
    ps
    Some links to see the Use Of My Table.
    http://www.color-dec.com/doming500W.mov
    http://developmentassociatesinc.com/scriptxyz.htm
    http://www.liquidcontrol.com/pdf/automation/c500.pdf
    http://domeit.com/
    http://www.efd-inc.com/xyz/index.html
    ...and Sorry for my Bad English... once again.
    Sep 2006
    34
    AH....and My Budget is About 7500-8500 USD....
    What do you think is the builing of this machine (with Servo) possible ????
    Feb 2005
    750
    It looks great. How much of your budget will be left for electronics after you buy all the hardware? This will have a lot to do with what type of servo system you can put on it.
    Is this a machine that has allready been built or a design only?
    Are you slaving two servos for the Y axis or will you use a belt drive and one motor?
    Halfnutz
    Sep 2006
    34
    about 3500 USD.
    Its a design only.
    I don't know what to do with that.
    I was thinking to buy a 4 or 5 Axis controller
    The one of them I want to use it to controll the the despence valve which have to be very accurate when despence the flood.
    Feb 2005
    750
    I dont know about lowcostcnc, I,ve seen thier ads for a long time, keep asking, re-post your questions if necessary, get as much advice as you can. You have enough budget to do it a number of ways, you probably dont need much torque but will want speed and accuracy. Definately ideal for a servo system.
    Halfnutz
