586,080 active members*
3,992 visitors online*
Thread: DESKPROTO
Results 1 to 9 of 9
    Jan 2015
    17
    DESKPROTO
    anyone using it? theres no area for it I get that they are still small so I figured this would be the best area to post this because aspire users will be doing similar type tool paths
    im seriously looking at buying the multixis package for 4th axis work, not a bad price at all
    do they have good support ?
    Apr 2004
    5737
    Re: DESKPROTO
    DeskProto has been around for quite a while, and it keeps getting better. It's still the least expensive option for 4th axis milling or routing, and it can do things that Aspire can only aspire to. It's intended for artistic rather than mechanistic parts, and produces toolpaths very quickly from large, complex mesh files. Even if you get the very inexpensive Hobbyist version, you can get support from the manufacturers through the forum on the DeskProto site http://www.deskproto.com/forum/forum.php?forumsubject=1 and if you buy it through a reseller (like us) you can get help from the reseller as well.
    Andrew Werby
    Website
    Feb 2009
    2143
    Re: DESKPROTO
    I have it in my suite of tools. As awerby stated, it is fast and good a complex toolpaths, especially for rotary axes. Certainly worth it (to me) even if I only open it a few times a year.
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Jul 2011
    218
    Re: DESKPROTO
    wrong thread
    Re: DESKPROTO
    the hobby version is 800 right now and still get support and 5 axis code
    It's about $288 US dollars right now for the Hobby license at the current exchange rate.
    Jul 2011
    218
    wrong thread
    Jan 2015
    17
    Re: DESKPROTO
    I think for 300 is the 3 axis hobby,
    multiaxis all the way for me, gonna use it to cut my zbrush models,
    edit
    now im confused a bit because I had a reseller quote me 795 for the multiaxis hobby license
    I would suggest that ifyou are not going to use the DeskProto in a business that you purchase theHobby version. That is a FULL multi axis version. Exactly like the $1200.00 oneexcept that Desk Proto offers only forum support on that release. Weoffer the hobby version for $795.00 with support.
    are there different multi versions other than commercial, edu and hobby or am I just getn ripped here by this fellow
    other sites concur with ger, 310 ish for a multiaxis hobby license
    for 300 I still get gcode? and forum support
    Nov 2008
    79
    Re: DESKPROTO
    Ger21 is right. $300 for the multiaxis hobby license. Just got my 4th axis running and using Deskproto to generate cylinder engraving G code from Inkscape DXFs for my Davinci under linuxcnc. Whew!
    Talk to awerby above. I got mine from him and he is very helpful.
    John C
    Jan 2015
    17
    Re: DESKPROTO
    wow ya so either that guy was tryin to swindle me or I don't know but ima buy from Awerby, who also comfirmed the price and is also reseller
  1. DeskProto
    By speedtwin69 in forum Uncategorised CAM Discussion
    Last Post: 09-14-2014, 08:28 PM
  2. does deskproto do 2d and 2.5d very well?
    By airbrush in forum Uncategorised CAM Discussion
    Last Post: 02-25-2014, 10:23 PM
  3. Deskproto - How to cut it out?
    By dan j in forum Uncategorised CAM Discussion
    Last Post: 10-19-2012, 09:24 AM
  4. Any reccomendations on DeskProto?
    By darinmurray in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-09-2010, 04:29 PM
  5. MeshCAM vs. Deskproto
    By CuttersCov in forum Uncategorised CAM Discussion
    Last Post: 03-14-2009, 12:33 AM
