586,103 active members*
3,791 visitors online*
Page 1 of 4 123
Results 1 to 20 of 65
    Jul 2014
    59
    What's causing this?
    Attachment 265406
    Ignore the hole. Forgot to zero the Z. Everything before the "I" is wrong. What could possibly cause this? Everything is strapped down good so there is no material movement. The machine will consistently make these movements.
    Mar 2006
    233
    Re: What's causing this?
    What program?
    Aug 2004
    2849
    I would try it again and if you see the same problem then I would suspect that your step setting for the x and or y are not correct.
    Have you tried routing out a circular path?
    Jul 2014
    59
    I've tried it multiple times. The issue looks a little different when I take the arc out. It seems the X will "forget" (for lack of better word) where it is. So one leg of the M will be longer than the other or an S will be a little squished. It is definitely the X axis but I'm not sure what causes it.
    The issue first showed up when cutting circles. It would get to the same place and be off at different depths but always in the same place.
    Mar 2006
    233
    What program? I have heard of this happening when people are trying to use bootleg copies of v carve and aspire.
    Feb 2007
    711
    infamous loose setscrew for pulley or coupler?
    Cut your velocity and acceleration in half and see if it helps.
    Jul 2014
    59
    I've tried slower speeds. I also did find a loose setscrew. I ran it again after taking care of both. Same issue.
    Feb 2007
    711
    replace cutting tool with a pen and do some testing on paper. draw circles, squares, diagonals, your failed program also.
    try slowing down and speeding up. watch closely as it moves. any strange noises?
    grab your spindle and force it around by hand. does it move?
    post your gcode. maybe like Klawz said, you might have a bum cam program.
    Mar 2006
    233
    Well he keeps dodging the question so it's looking like my theory has traction.
    Jul 2014
    59
    Cut 2D...straight from Vectric.
    - - - Updated - - -
    Theory is bunked
    Mar 2006
    233
    I knew it was a vectric program. They act EXACTLY like that when you have a hacked copy.
    If you got it straight from them or not you may want to check your install and how you activated it.
    Jul 2014
    59
    Goode isn't the issue. I've actually run the same program and had no issues previous to this problem. It started on a bigger job. I had finished the job and wanted to cut it a little deeper so I restarted the program. Nothing seemed out of ordinary until it started cutting small circles and it cut them bad out of round.
    Jul 2014
    59
    How in the world do you get a hacked copy that was downloaded from the Vectric site?
    Mar 2006
    233
    It's not the download it's how it was activated.
    I don't have any of their programs but I have seen guys going around about this on other forums.
    Jul 2014
    59
    Soooo.....it ran fine for some time but now decides to mess up? What am I missing?
    Mar 2006
    233
    Yep, that's how it was happening.
    Jul 2014
    59
    And the solution is......?
    Mar 2006
    233
    In those cases it was to buy a legit copy, they had some wild safeguard built into the software to prevent piracy.
    But if you insist that you bought it from them I suggest you call them.
    Feb 2007
    711
    If it's not the gcode, then it is your machine.
    Can you post the gcode and a picture of your machine?
    are you familiar of the sound of a stalled stepper? maybe this is happening intermittently.
    any other loose setscrews? even if they are tight, the interface between pulley and shaft can slip back and forth, and it is hard to tell without marking each, and checking often.
Page 1 of 4 123
  1. New Genos causing BIG problem!
    By stude8 in forum Okuma
    Last Post: 09-18-2012, 12:21 AM
  2. What is causing this?
    By Dstoddart in forum DIY CNC Router Table Machines
    Last Post: 08-24-2011, 02:06 AM
  3. Wobbly spindle, what's causing it please?
    By ImanCarrot in forum Bridgeport / Hardinge Mills
    Last Post: 03-10-2010, 10:45 AM
  4. What is causing this?
    By cxixer in forum WoodWorking Topics
    Last Post: 06-11-2008, 08:05 AM
  5. VFD causing issues
    By Smackre in forum CNC Machine Related Electronics
    Last Post: 11-22-2006, 02:26 PM
