586,114 active members*
3,199 visitors online*
Results 1 to 6 of 6
    Mar 2014
    23
    DM542A stepper driver
    I just got my cnc kit and hooked them all up for a test run and there is one that has a blinking green light. I switched the motors around and still the same thing.
    any ideas on whats wrong?
    Feb 2007
    4553
    Re: DM542A stepper driver
    Poorman56,
    Remove the wire connected to the enable.
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Mar 2014
    23
    removed the wire and it still blinks
    Feb 2007
    4553
    With power supply off remove all wires except power wires then power back on and see if led flashes.
    Did you figure out what as wrong? I am having the same poroblem with my DM542A. I dont have the jumper enable and I see that that was the last comment on the feed...?
    Jul 2020
    Quote Originally Posted by Tainoworks View Post
    Did you figure out what as wrong? I am having the same problem with my DM542A. I don't have the jumper enable and I see that that was the last comment on the feed...?
    Know this is resurrecting a dead thread but I am having the same issue with a DM542S, blinking green light. Followed the suggestions above but the issue still persists. There is NO documentation out there for a flashing green LED on these drivers. Any help appreciated.
  1. Replies: 25
    Last Post: 02-18-2017, 01:02 AM
  2. Replies: 7
    Last Post: 01-10-2015, 05:49 PM
  3. Wich kit should i choose? DM542A or TB6560
    By crimar in forum Stepper Motors / Drives
    Last Post: 12-21-2013, 03:21 PM
  4. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  5. STEPPER DRIVER FAQ {Stepper/driver amp per phase match.
    By huios in forum Stepper Motors / Drives
    Last Post: 08-27-2006, 02:43 PM
