586,036 active members*
3,578 visitors online*
    May 2010
    63
    Modification for plasma?
    Been thinking of a way to mod the table to use for plasma also. Has anyone done this? I was thinking of a water pan type just to keep sparks down. Of course proper shielding and all that.Thin metal ( metal art stuff ) so not as much air pressure needed, wouldn't need a drain system or anything, I would just clean it out at the end of the day. It's a 2x4' joes that I got some time ago from Kent on this forum and it works well but I'd like to incorporate metal art to.
    Chris.....Everyday is a Good day.....if you wake up breathing!
    Joe's 2006, Mach3, Vectric software.
    Aug 2004
    3215
    Re: Modification for plasma?
    Here is one which a member modified the 4x4 hybrid machine, he used just aluminum angle layed down for the bed and when he want to use a router he uses some mdf ontop.
    Note he also changed the X-Axis (Gantry to use a belt drive to gain the speed a laser needs).
    Attachment 266396
    https://www.youtube.com/watch?v=TG8G7F30j6I
    You can do something similar with a plasma for the bed.
    Joe
    www.joescnc.com
    joecnc2006 at yahoo
  1. Spindle Key Modification
    By cnckid in forum Uncategorised MetalWorking Machines
    Last Post: 08-06-2012, 10:02 PM
  2. need help with modification
    By ironofeden in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-23-2011, 06:21 PM
  3. Post modification
    By westerfieldcct in forum BobCad-Cam
    Last Post: 12-11-2010, 05:28 PM
  4. Taig Modification
    By CROSSHATCH in forum Taig Mills / Lathes
    Last Post: 10-05-2008, 03:10 PM
  5. New MCG's need modification
    By Swede in forum Servo Motors / Drives
    Last Post: 01-12-2005, 03:46 PM
