586,082 active members*
3,534 visitors online*
IndustryArena Forum > MetalWorking Machines > Deckel, Maho, Aciera, Abene Mills > CTX 510 Coolant pressure and flow rate is too low
    Jan 2014
    15
    Hi every one, hope all of you are fine....
    I have a problem in CNC turning machine (CTX 510 eco - DMG), the cooling fluid which goes out from the tools in the turret has a low pressure and flow rate and I checked the following:
    1- The pump is Ok
    2- The pressure and flow rate which arrive to turret inlet is Ok
    3- I tried to clean the coolant path in the turret by using air
    But the problem still exist, so I need help from you to solve this issue.
    Thank you
    Jan 2014
    15
    Re: CTX 510 Coolant pressure and flow rate is too low
    Hey People ....... :stickpoke where are the answers?
    I need your help experts. :drowning::drowning:
  1. Twist rate/pressure
    By Danny1203 in forum Gunsmithing
    Last Post: 12-08-2017, 01:13 AM
  2. K-15 No Coolant Flow
    By eustisfixer in forum Hyundai Kia
    Last Post: 08-08-2012, 01:18 PM
  3. Monitoring Air Flow as opposed to Air Pressure
    By Beefy in forum Waterjet General Topics
    Last Post: 01-16-2012, 05:17 PM
  4. How to control the flow rate in a 3-phase pump?
    By Ed from NY in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2011, 07:45 AM
