586,113 active members*
3,103 visitors online*
IndustryArena Forum > MetalWorking Machines > Hitachi Seikis > Hitachi Seiki VM40 with Seicos MII
    Dear All,
    I hope that someone could help me to make my machine work again, after a long time turned the machine one, and i'm getting the following alarms :
    +x over-travel
    - x over-travel
    +y over-travel
    - y over-travel
    +z over-travel
    - z over-travel
    parameter pitch error (x)
    parameter pitch error (y)
    parameter pitch error (z)
    in addition to the above alarms, the operation panel and the key board does not respond, also the relay board seem to me died
    sting
    Jan 2015
    42
    Re: Hitachi Seiki VM40 with Seicos MII
    Hi Sting,
    Looks like your parameters have gone south. I hope you have a
    master sheet in the back cabinet? Your battery may have gone
    dead and you lost the brains
    Thanks for your reply,but even if i got the parameters ;how to load it while the key board and the operation panel does not respond?can you tell me the procedure to load parameters?
    Sting
    Dec 2009
    539
    Sting, not only did you lose parameters but the ladder as well. That is why you cannot use the keyboard. Do you have a backup copy?
    John
  1. Hitachi Seiki VM40 seicos 2
    By bevins in forum Hitachi Seikis
    Last Post: 05-08-2013, 04:06 AM
  2. hitachi seiki vm40 error 141
    By Mousie in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-15-2009, 10:10 AM
  3. Hitachi Seiki VM40 with Seicos M2 control
    By djackson854 in forum Uncategorised MetalWorking Machines
    Last Post: 07-15-2008, 11:50 AM
