586,116 active members*
3,460 visitors online*
Thread: Wire tension
    Nov 2004
    26
    Wire tension
    Dose anyone know how tight the wire should be in pounds of pull. I am designing a wire tension system and need to know where to start.
    Gary
    Depron Laser Cutting
    http://www.depronlasercutting.com
    Sep 2006
    18
    wire tension
    depends on the wire, .020" or 24 ga. with 1.6 initial and 6lb/ft max works well for me.
