thank you
i will be waiting
thank you
i will be waiting
I have had good success using sodium silicate (water glass from the potery supplier) mixed with silica flour (also from potery supplier.) This mix is really similar to the commercial slurries they use for building shells, just alot cheaper. Dip it in that and let it dry, repeat acouple of times. Then dip it and sprinkle kitty litter on it to build some thickness. This works good for aluminum, I think it gets soft at highter temps, like for iron, I don't know- haven't tried it... I have also had good results with NO coating. Pack it in dry sand and pour right on top of the styro cup. It burns out everything, including the toothpicks I leave in the joints! The surface detail on this is as fine as the sand you pack it in (usually!)
