Hey guys, so i will try my best to explain this issue. We didnt used drip feed until we tryed yesterday, i need to run programs from the PC using drip feed because the transmition using TA,1 is takin forever (2-3hours).
So yesterday i set everything on the machine ready to work like this:
Set de Baud rate in the fadal using the command CD,8>Enter
DNC>Enter
Start
From CIMCO i sent the program, once i clicked the send botton, the machines started working. On Cimco i changes de baud rate at 9600 too.
I erased every comment and the program name too, also deleted all the numbers on the lines.
This worked very well on a couple of small programs i ran. But once i started a big program the system kept running but it displayed many errors on the process and also the slide hold was dissabled for some reason.
Today the crew try to send it via drip feed and they coudnt make it work so they try to go back to send it using TA,1, and it didnt work, the machine displayed a RS232 error.... so i told them to change the baud rate on the CIMCO back to 2400. And it worked....
Right now we are sending programs to the memory again, but the FADAL is set a 9600 baud rate and the pc ar 2400. How is this possible????
I really need to make the drip feed work, any ideas?
