586,108 active members*
3,321 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mazak, Mitsubishi, Mazatrol > MAZAK QUICKTURN- ALARM 21 DRIVER UNIT POWER MULFUNCTION
    Sep 2013
    8
    I am using Mazak Quickturn 20 machine, machine is giving alarm - Alarm 21 Driver Unit Power Mulfunction
    Machine is normally working when started by spindle manually and on 300 rpm or higher, but when working when I stop the machine on 300 rpm or 800 rpm and then I start the machine again and it gives alarm 21.
    If I start the machine automatically, on 300 rpm it is working, but if I write 1.500 rpm on programme, machine is giving 21 alarm again.
    The modüle in driver unit has been changed, but again giving 21 alarm.
    We cannot find where the problem is, if you can give advice I will b very pleased.
    Oct 2003
    321
    Re: MAZAK QUICKTURN- ALARM 21 DRIVER UNIT POWER MULFUNCTION
    you get the alarm #21 on the monitor, or on the drive MDS .... ?
    best regards
    mazak-user
    Sep 2013
    8
    ON THE MONİTOR ALARM 21 DRIVER UNIT POWER MULFUNCTION , ON MDS ALARM 32 AND F6
    CAN YOU HELP?
    Jun 2012
    36
    May be you can check the spindle pulley belts or the encoder timer pulley belts for slipping.
    Regards
    SHEKAR
    Oct 2003
    321
    I think your MDS... must be repaired.
    Sorry!
    Best regards
    Mazak-user
  1. 21 Drive unit power malfunction 1,0,&0023 alarm
    By JOEC8 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-16-2014, 07:24 PM
  2. Mazak QuickTurn 10N Control T2
    By CNC Machine OT in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-08-2014, 11:19 AM
  3. Mazak QuickTurn 10N Control T2
    Last Post: 02-06-2014, 07:10 AM
  4. mazak fh6800 atc driver alarm
    By waseem sajjad in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2010, 01:46 PM
  5. mazak t32-2, quickturn 8n
    By Enda in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-09-2006, 11:00 PM
