586,106 active members*
2,987 visitors online*
Results 1 to 8 of 8
    May 2012
    32
    China 3020 3040 routers
    I have one of these routers, the 3020 and found out that movements on all the axii had some missing steps as has been reported
    on this forum.
    So I decided to do the filter cap mods as described elsewhere here but found that didn't help a whole lot since I still had missing steps
    and after doing some more searching here found another mod adding a Schmidt trigger inverter chip from the opto outputs for steps to the drivers.
    After this mod was done I found one of the axis was no longer moving in both directions so I must have zapped that driver chip.
    Rather than replace the chip I decided to take some of the advise here and replaced the driver PCB with a Gecko G540. WOW what an
    improvement, no missing steps at all !
    So because of the way the Chinese driver PCB was designed and not using the guidelines for that driver chip as presented by the chip maker
    some that decide to make the mods may find it may not help and others feel it did the trick but my opinion is replace that POS driver
    with the G540 you won't regret it.
    Apr 2013
    56
    Re: China 3020 3040 routers
    I made the same replacement after fighting it for a year, runs like a champ now. May I ask what numbers you tuned your motors to, I'm using Mach3
    Thanks in advance
    May 2012
    32
    12,700 steps per inch.
    But need to increase the velocity from where I had decreased it. A bit too slow. I don't have
    the acceleration or velocity numbers handy.
    Nov 2010
    8
    I just bought one of these Chinese 3040 machines and ordered the G540 as well. Is their a online "how to" to swap this over? Searched for awhile and cannot find it :/
    May 2012
    32
    I haven't found one either but it isn't difficult to make the replacement.
    What I did was keep the power supply and spindle motor the same, mine was working ok and hasn't caused any
    issues as of yet, I am not using the PWM spindle control or relay output to turn the spindle on/off. I used the cabinet too, I cut out the back side of the
    cabinet and left an edge that is about 3/8" all around keeping the threaded holes
    for mounting the cover. I then cut out a piece of 1/8" thick aluminum that mounts on the inside using #4-40 hardware, flat head screws up top
    and pan head screws at the bottom. I also cut out reliefs for the cabinet screws that poke through when attaching the cabinet cover.
    I mounted the G540 and spindle jack plus a 8 pin jack for limits and probe on the aluminum plate with the G540 above and other jacks at the
    bottom. Along with the jacks is a fuse holder and a power cord grommet (power cord entry module would not fit). I re-used the X Y and Z 4 pin motor jacks
    by removing the molex connectors and wiring jacks to the DB9's that came with the G540, this makes a short adapter (4 pin mic to DB9) that works fine and you
    don't have to replace the motor plugs.
    May 2012
    32
    Oh forgot to mention that I mounted the fan inside of the cabinet at an angle that pushes air against
    the back of the G540 for cooling.
    Jul 2006
    887
    The hardest part about the G540 is wirering the motors and not forgetting about the current limit resistor in the motor plug. G540 is a great stepper drive and a breaze to setup in mach.
    Nov 2010
    8
    Quote Originally Posted by w7bcw View Post
    Thank you for taking the time to post that!
  1. 3020/3040 Can I just connect a probe to this controller pcb?
    By Teajunkie in forum Chinese Machines
    Last Post: 01-07-2015, 09:33 AM
  2. 3020/3040/6040 backlash?
    By m_c in forum Chinese Machines
    Last Post: 07-26-2014, 11:55 PM
  3. Replies: 3
    Last Post: 05-02-2014, 11:31 AM
  4. 3040 or 3020 seller
    By juano2001 in forum Chinese Machines
    Last Post: 12-31-2012, 11:10 PM
  5. Need to buy a entry level CNC Router like CNC 3040\3020
    By zegeli in forum CNC Wood Router Project Log
    Last Post: 09-04-2012, 06:37 PM
