586,102 active members*
2,601 visitors online*
IndustryArena Forum > MetalWorking Machines > Daewoo/Doosan > Resetting home position Puma 240 21iTB control
Results 1 to 7 of 7
    Jun 2007
    84
    Looking for help resetting the home position on a Puma 240B with Fanuc 21iTB control.
    When I indicate a round holder, X is at -.0624 instead of zero.
    Jun 2004
    511
    Re: Resetting home position Puma 240 21iTB control
    Do you have abs encoders?
    Jun 2007
    84
    Quote Originally Posted by ifixcnc View Post
    Yes.
    Jun 2004
    511
    I dont have my 21I book with me at this point. APZ and APC are the parameters to set zero. You move to the location that you want to be Zero and turn them off then on. #1815 rings a bell. Check your parameter book.
    Feb 2013
    788
    Doing it as described will cause the location to become the Home/reference position, not X0.0
    Doosan Service Technician
    [email protected] O:973-618-2461 M:973-803-9479
    Feb 2013
    788
    First question: is it true in Y direction?
    If yes = continue.
    If no = turret knocked out position and repair is needed.
    Write down the value of parameter 1240 for X
    Reference machine (handwheel is not as accurate as auto, so specific use gives better outcome)
    dial handwheel toward center without changing direction.
    Sweep X moving only downward to find 0
    Display the relative position
    Origin the 0 swept location
    Move positive, in relative, to the value from 1240
    Go to MDI MODE with PWE enabled
    Goto parameter 1815.4
    Set it to 0
    Set it to 1
    Reboot the machine
    Reference the machine
    SAFELY send the axis to 0 in automatic and check
    Whatever amount that you are off, repeat the process using this known offset amount to correct for deviations of the handwheel.
    Jun 2007
    84
    Thanks, got it!
  1. Replies: 3
    Last Post: 06-21-2011, 06:49 PM
  2. Puma 400 with 21iTB control
    By bala955 in forum Daewoo/Doosan
    Last Post: 06-12-2010, 04:57 PM
  3. Fanuc 6MB Tool position is resetting to #1
    By moldmker in forum Fanuc
    Last Post: 11-06-2008, 05:29 AM
  4. Ok Newbie :) Resetting Home after a Fault
    By Anxious in forum WoodWorking Topics
    Last Post: 10-24-2008, 07:28 AM
  5. Changing/resetting the table position during a tool change?
    By Jim Ster in forum Mori Seiki Mills
    Last Post: 08-13-2008, 01:31 PM
